EIGRP problem
mlimouni821
Visitor
Hi Everyones
I create a network infra with BGP and EIGRP. There is 5 routers, The connection between R1 and R2 is BGP. R2, R3, R4 and R5 are EIGRP. The configuration is done and the ping works well only R1 can't ping R5 ( R5 can ping R1 ).
I upload the hole configurations in a zip file with a picture of the lab
Thanks for help 🙂
Ganesh Hariharan
Hi Everyones
Thanks for help 🙂
I have checked the configuration, Can you check what output is depicting in R1 for R5 subnets and in R2 as well.
If subnets are reaching R2 and not in R1 need to re-check on re-distribution.
Hope it Helps..
-GI
Rate if it Helps..
Dennis Mink
what IP address on R5 are you pinging on R1?
and what does sh ip route x.x.x.x say on R1 for that IP address?
Please remember to rate useful posts, by clicking on the stars below.
Ganesh Hariharan
Hi Everyones
Thanks for help 🙂
Hope it Helps..
-GI
Rate if it Helps..
The depicting in R1 gave me the solution. I discovered that I forgate a loopback1 in R1 with the IP address 10.1.5.1, the same subnet like the loopback0 of R5 10.1.5.5.
After I deleted it, the ping from R1 to R5 works properly.
Thanks Lot.
