EIGRP redistribute static issue
Adam Hudson
I have an EIGRP issue hopefully someone can help me with. I have a 2821 router with three static routes to VLANs that exist on a switch it's connected to. I want to share these routes with the rest of my network. I thought a "redistribute static" command would do this, but it does not.
I can run a "show ip eigrp topology <network> <network mask>" on the router and other equipment in the eigrp network and the network information comes up, but I can't ping any of the VLANs from anything but the router. My EIGRP statement also includes "no auto-summary" but that does not help either. Below is the results of the "show ip eigrp topology" command.
router#sh ip eigrp XXX top 10.X.47.0 255.255.255.0
IP-EIGRP (AS XXX): Topology entry for 10.X.47.0/24
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 28160
  Routing Descriptor Blocks:
  10.X.0.15, from Rstatic, Send flag is 0x0
      Composite metric is (28160/0), Route is External
      Vector metric:
        Minimum bandwidth is 100000 Kbit
        Total delay is 100 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 0
      External data:
        Originating router is 10.X.X.3 (this system)
        AS number of route is 0
        External protocol is Static, external metric is 0
        Administrator tag is 0 (0x00000000)
15 Replies 15
That makes sense, I should've taken a look at some of the other EIGRP connections on my network to see what they had in common. Thanks for your help Jon.
