EIGRP redistribute static routes into eigrp process
Mokhalil82
Level 4
Level 4
Hi Guys
I want to know how I can reistribute my existing static routes into an eigrp process on a L3 switch so these can be advertised to the EIGRP neighbors. May need a route map of some sort I believe
For 6800 series IOS it should be
"redistribute static metric" with route-map optional.
is redistribute static available under EIGRP?
here is link with 2 different options:
http://etherealmind.com/quiz-redistributing-static-eigrp-better/
Reza Sharifi
Usually that is the case with Nexus series.
What type of device are you using?
Reza
Im using a 6880x
