EIGRP relationship
Maurice Ball
Level 6
Level 6
I am having issues running the eigrp routing protocol between my router and ASA firewall. The relationship between the two devices keeps resetting every 5 minutes. I can not determine what is causing the problem. The relationship between the other eigrp neighbors that are connected to the router is working fine. Any help would be greatly appreciated.
Note: The firewall is configured in a failover cluster.
EIGRP-IPv4 Neighbors for AS(10)
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
0   10.21.10.5                Gi0/0                    14 00:02:57    1   100  0  939162
4   10.10.17.3              Tu10                     14 01:17:05   21   132  0  2570
3   10.21.118.100              Gi0/0                    12 01:17:17    1   100  0  16310
2   10.21.81.101              Gi0/0                    14 01:17:17    1   100  0  13111
1   10.21.84.10               Gi0/0                    14 01:17:17    1   100  0  208135
Hello
I see that you have auto-summarisation enabled on the router and disabled on the ASA.
Depending on what IOS train your are using - any neighbor change would be logged -  under the  eigrp process of the router
router eigrp xx
eigrp log-neighbor-change
no auto-summary
Then can you post these logs of the neighbor resetting?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
12 Replies 12
paulstone80
Level 7
Level 7
How have you got the neighborship configured? Have you set the neighbors statically or are you using dynamic neighbor discovery?
Are you using authentication at all?
Paul
****Please rate useful posts****
HTH Paul ****Please rate useful posts****
No, authentication.
eigrp  config on router
router eigrp 10
network 10.0.0.0
passive-interface default
no passive-interface Tunnel10
no passive-interface GigabitEthernet0/0
eirgp config on ASA
router eigrp 10
no auto-summary
network 10.0.0.0 255.0.0.0
redistribute connected
redistribute static
Hi Maurice,
Your network statement on the ASA should be using a wildcard mask.
Paul
Yes, that is what i was thinking but the ASA allows only the following:
fw01# config t
fw01(config)# rout
fw01(config)# router eigrp 10
fw01(config-router)# net
fw01(config-router)# network 10.2.8.8 ?
router mode commands/options:
  Hostname or A.B.C.D  Mask for network address
eidfw01(config-router)# network 10.2.8.8
Does it not allow network 10.0.0.0 0.0.0.255 ??
Paul
Sorry, I meant network 10.0.0.0 0.255.255.255
Paul
The ASA requires a network mask not a wild card mask.
fw01(config-router)# network 10.0.0.0 0.255.255.255
% EIGRP: Invalid mask (discontiguous)
Hello
router eigrp xx
no auto-summary
res
Paul
Thanks.
Kind Regards
Paul
ok thanks I will add it.
Maurice Ball
Level 6
Level 6
I've noticed that when I ping EIGRP multicast address 224.0.0.10. I get a reply from all of the eigrp devices except for the firewall.
eiddmvpn#ping 224.0.0.10
Sending 1, 100-byte ICMP Echos to 224.0.0.10, timeout is 2 seconds:
Reply to request 0 from 10.2.8.10, 4 ms
Reply to request 0 from 10.0.117.3, 28 ms
Reply to request 0 from sw (10.2.8.100), 4 ms
Reply to request 0 from sw2 (10.2.8.101), 4 ms
The firewall address is: 10.2.8.5
When I ping the multicast address from the firewall there are no replies received.
Could this be what is causing the problem?
can you clarify first if your eigrp relationship.is now working ?
then can you clarify the configuration of the inside interface pointing to the router on the asa - should be something like:
int xx
nameif inside
security level 100
ip address 10.x.x.x y.y.y
also do.you have any acls defined?
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
firewall interface:
interface Port-channel1.18
vlan 80
nameif inside
security-level 50
ip address 10.2.8.5 255.255.255.0 standby 10.2.8.6
Router interface:
description Linknet
ip address 10.2.8.8 255.255.255.0
