eigrp route distribution issue
lkadlik
hi,
I am trying to advertise the following network to my other offices /eigrp peers
10.20.147.0/24
The network exists via  a static route on the router i need to advertise it from.  when i go under the eigrp config and say "redistribute static" it advertises the route.  The issue is there are other statics that I do not want advertised. This is the only static that I want to be advertised from this core.  When I tried the following the new network was not advertised.
route-map StaticVPN_to_EIGRP permit 10
match ip address 120
set metric 10000 100 255 1 1500
access-list 120 permit ip 10.20.147.0 0.0.0.255 any
router eigrp 7
redistribute static route-map StaticVPN_to_EIGRP
Thoughts?
Thank you.
Lynne
cadet alain
use a standard ACL or better a prefix-list to redistribute the static route.
ip prefix-list REDISTR_STATIC permit 10.20.147.0/24
match ip address prefix REDISTR_STATIC
Regards.
Alain
8 Replies 8
cadet alain
Regards.
Alain
I am sorry.  This is probably a dumb questions but why is a pre-fix list better/correct compared to an acl?
thanks
Lynne
only a prefix-list can match on both prefix and prefix-length.an ACL will only match on the prefix and not the prefix-length
so you may end up redistributing routes you don't wish to.
Regards.
Alain
fb_webuser
Level 6
Level 6
Use a standard ACL: ip access-list standard NAME and permit 10.20.147.0 0.0.0.255
OR
You can use a prefix-list: ip prefix-list NAME 5 permit 10.20.147.0/24
Posted by WebUser James Holley from Cisco Support Community App
fb_webuser
Level 6
Level 6
fb was having issues and did not see @cadetalain most excellent post that ties in the change in route-map syntax adding the "match ip address prefix" keyword.
fb_webuser
Level 6
Level 6
To answer your question it is not better, just most tech professionals now use them in place of ACL. When using an ACL for route-map filtering you need to use a Standard ACL which has the command syntax: access-list access-list-number deny source .
With access-list 120, in your case your syntax is sor source and destination pair and protocols- too numerous to list here, but the bottom line is that you use standard ACL when using access-lists, because when using extended ACL it leads to tech issues. I think in your case you originally used access-list 120 permit ip 10.20.147.0 0.0.0.255 any
which means permit the ip protocol from source 10.20.147.0/24 (hosts 1-254 of that segment) to any destination. This would be used in a situation wher you were blocking/allowing traffic from a lan to a destination through the router (router as a filter)
Sorry, I was answering from fb app. Second sentence in the post should have been:
access-list access-list-number [deny|permit]  source [source-wildcard] [log]
CCIE 5648
fb_webuser
Level 6
Level 6
You can use distribute-list to filter routes.
router eigrp 7
redistribute static metric 10000 100 255 1 1500
distribute-list 120 out static
auto-summary
access-list 120 permit ip any 10.20.147.0 0.0.0.255
HTH,
Eduardo Campos
Posted by WebUser Eduardo Campos from Cisco Support Community App
