EIGRP routing
fgasimzade
Level 8
Level 8
The issue is to configure routers with EIGRP to send only desired routes. I heard this is somehow done through prefix lists and route map, but I dont know exactly. Has anyone dealt with it? Or can anyone suggest any links with configuration guide?
royalblues
Level 11
Level 11
Ypu would be required to use distribute lists for filtering routes from advertising.
The distribute-list can reference an access-list or prefix-list
eg. say R1<--->R2 R1 runs eigrp on all its interfaces but needs to send routing updates only for loopback1
R1
interface Loopback1
ip address 1.1.1.1 255.255.255.0
interface Loopback2
ip address 2.2.2.2 255.255.255.0
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.0
router eigrp 1
network 1.0.0.0
network 2.0.0.0
network 10.0.0.0
distribute-list prefix test out
no auto-summary
ip prefix-list test seq 10 permit 1.1.1.0/24
R2
ip address 10.10.10.2 255.255.255.0
router eigrp 1
network 10.0.0.0
no auto-summary
Router#sh ip route
Gateway of last resort is not set
1.0.0.0/24 is subnetted, 1 subnets
D 1.1.1.0 [90/156160] via 10.10.10.1, 00:06:50, FastEthernet0/0
10.0.0.0/24 is subnetted, 1 subnets
C 10.10.10.0 is directly connected, FastEthernet0/0
Router#
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfindep.html#wp1001343
Narayan
royalblues
Level 11
Level 11
R1
interface Loopback1
interface Loopback2
router eigrp 1
network 1.0.0.0
network 2.0.0.0
network 10.0.0.0
no auto-summary
R2
router eigrp 1
network 10.0.0.0
no auto-summary
Router#sh ip route
Router#
Narayan
Thank you, this is what I was looking for
johnlloyd_13
Level 11
Level 11
try using redistribute..as for route maps, it's mainly used for bgp (for policy based routing or PBR)
