enable dashboard on cisco 2950
Srinivas N
Dear Friends,
I have 2 cisco 2959 switches & both are same version and same configuring.
When I login in web based, switch_1 is not show deshboard, and switch_2 is showing deshboard,
And even I upgraded the IOS version in switch_1 still dashboard is not showing.
In below both are desplied verson & configruation also,
Please guide me how to enable the deshboard on switch_1 also.
Switch_1(web based, version & configuration)
GP_VIZAG_MAINSW_2950#sh run
Building configuration...
Current configuration : 3705 bytes
! Last configuration change at 19:56:09 IST Fri Oct 4 2013 by ttl@wifi
! NVRAM config last updated at 19:58:08 IST Fri Oct 4 2013 by ttl@wifi
version 12.1
no service pad
service timestamps debug uptime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
hostname GP_VIZAG_MAINSW_2950
enable secret 5 $1$n5EA$TqZXqAINeMA3.CiCds.qq.
username ttl@wifi privilege 15 password 7 0030272A246C222026
username test privilege 7 password 7 0010161510
clock timezone IST 5 30
ip subnet-zero
no ip domain-lookup
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan 10,174
interface FastEthernet0/1
description * ROOM SERVICE SW_2950 *
switchport trunk allowed vlan 10,174
switchport mode trunk
interface FastEthernet0/2
description * B-CENTER *
switchport access vlan 10
switchport mode access
interface FastEthernet0/3
description * Telephonic Room *
interface FastEthernet0/4
description * TOWER-I (Proxim) *
interface FastEthernet0/5
description * BACKSIDE-I (Proxim) *
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
switchport access vlan 174
interface FastEthernet0/12
interface FastEthernet0/13
switchport port-security
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
description * CONNECTED FROM PRONTO LAN PORT *
interface FastEthernet0/21
interface FastEthernet0/22
description * CONNECTED TO ADMIN NETWORK *
interface FastEthernet0/23
description * CONNECTED TO PRONTO WAN PORT *
interface FastEthernet0/24
interface GigabitEthernet0/1
description * B/W_ROCKDALE_AS *
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
no ip address
no ip route-cache
shutdown
interface Vlan100
no ip address
no ip route-cache
shutdown
interface Vlan174
ip address X.X.X.X 255.255.255.240
no ip route-cache
ip default-gateway X.X.X.X
ip http server
snmp-server community public RO
line con 0
password 7 13061E010803
line vty 0 4
password 7 071B35406E1E10031E
login local
line vty 5 15
password 7 0010100F17572B11062745
login
end
Switch_2 (Web based, version & configuration)
GP_VIZAG_FLOORSW_2950#sh run
Current configuration : 3223 bytes
version 12.1
no service pad
service timestamps log uptime
hostname GP_VIZAG_FLOORSW_2950
enable secret 5 $1$Y5wP$e0XqvQuRrrszZR295/.By/
username ttl@wifi privilege 15 password 7 107A3D3525203B2D25
username test privilege 7 password 7 15060E1F10
ip subnet-zero
no ip domain-lookup
vlan 10,174
description * UPLINK_GF-1 *
description * UPLINK_GF-2 *
description * UPLINK_GF-3 *
description * UPLINK_GF-4
description * UPLINK_GF-5 *
description * UPLINK_GF-6
description * Forum AP *
description * Consolete AP *
description * Chansari AP *
description * BACKSIDE-II (Proxim) *
description * UPLINK FROM MAIN SW *
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
no ip address
no ip route-cache
shutdown
interface Vlan174
ip address x.x.x.x 255.255.255.240
no ip route-cache
ip default-gateway x.x.x.x
ip http server
line con 0
line vty 0 4
password 7 140306072C13232D2D
login local
line vty 5 15
login
end
Thanks & Regards,
Srinivas. N.
Thanks & Regards,
Srinivas.
acampbell
Srinivas,
May be your CMS files (part of a tar archive) has been corrupted anr not properly upgraded
Have a read at this link:-http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a0080169627.shtml
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi Acampbell,
Thanks for repoly, but after upgraded the IOS also, I am not able to get the dashboard on switch_1.
And I noticed that, so many switches not getting dashboard,
And I have a small querry, existing file is .bin, if I uploaded .tar... won't get any issue?
Thanks & Regards,
Srinivas. N.
Thanks & Regards,
Srinivas.
