Enable EIGRP on Cisco 9500 switch?
jjevans1
Hello All,
I have a 9500 that does not allow EIGRP. How do I enable it on the 9500 series switch?
C9500(config-if)#ip router ?
isis IS-IS Routing for IP
Version: Version 17.8.1r
Thank you for your insight.
J
I think you come from NSK experience
In c9000 you need to use
Router eigrp AS <- in global mode
Then
Network <subnet of interface>
MHM
Then
MHM
Ok I see it now thank you. How do I do DHCP relay then?
ip dhcp relay address X.X.X.X
Under interface
ip helper-address <dhcp server IP>
MHM
