Enable jumbo frames on interface - Layer 2 - Nexus 31xx series
We would like to verify that jumbo frames are enabled and MTU size is to 9216, for all Layer 2 switches in our data center.
QUESTION: Is there anyway to set the interface MTU to 9216 bytes??
We have run the following commands:
1.    # show  run all | in jumbomtu
system jumbomtu 9216
policy-map type network-qos jumbo
  service-policy type network-qos jumbo
2.    # show run ipqos
  class type network-qos class-default
    mtu 9216
system qos
3.   # show queueing interface e1/32
Ethernet1/32 queuing information:
    qos-group  sched-type  oper-bandwidth
        0       WRR            100
    qos-group 0
    HW MTU: 9216 (9216 configured)
    drop-type: drop, xon: 0, xoff: 0
    Statistics:
        Ucast pkts sent over the port           : 4131595597
4.  # show run | sec policy-map
    mtu 9216
5.  # show run | sec “system qos”
system qos
6. ***For all interfaces though, we get the below output:****
# show interface e1/32 | in MTU
 MTU 1500 bytes, BW 40000000 Kbit, DLY 10 usec
Thank you.
Reza Sharifi
The MTU can only be setup for the entire switch and not per interface.
Based on the outputs above, can we declare that jumbo frames has been enabled on this Layer 2 switch.
Does VLAN MTU config apply to Layer 2 switching?
Thanks.
Yes, based on the output jumbo frame is enabled for the switch.
On this platform, I don't think you can enable it per vlan.  I think you can only do it for the whole switch.
Thank you!
