Enable Mode (Cisco 2911)
ashleyreed4218
Hi!
My engineer onsite can't get into enable mode on his 2911 router. I've seen this before but I can't find out how I fixed it.
He gets an error saying : no password set
Anyone have any suggestions?
Thank you always,
AR
Here is the config:
Router#sh run
Building configuration...
Current configuration : 1784 bytes
! Last configuration change at 20:10:18 UTC Wed Oct 31 2012
! NVRAM config last updated at 20:10:11 UTC Wed Oct 31 2012
version 15.1
hostname Router
boot-start-marker
boot-end-marker
card type t1 0 0
no aaa new-model
no network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
no ip domain lookup
license udi pid CISCO2911/K9 sn FGL162311MY
controller T1 0/0/0
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/0/1
controller T1 0/0/2
controller T1 0/0/3
interface Embedded-Service-Engine0/0
no ip address
ip broadcast-address 0.0.0.0
shutdown
interface GigabitEthernet0/0
ip address 192.168.50.103 255.255.255.0
ip pim sparse-mode
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
ip pim sparse-mode
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
ip address 192.168.52.1 255.255.255.0
ip pim sparse-mode
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.62.0 255.255.255.0 192.168.52.2
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
(he just added the password for this)
transport input all
scheduler allocate 20000 1000
end
Router#
2 Accepted Solutions
you have to set enable password: enable secret 0 strong-password
Richard Burts
I do not see either an enable secret configured or an enable password configured. With no password for enable mode he should be able to access privilege mode from the console but not from any other connection (such as telnet).
To fix the problem you need to access the console port, get into enable mode, and configure the enable secret.
Rick
Rick
Thank you!
Richard Burts
Rick
Rick
