Enable port security between Two switches
mahesh18
Level 6
Level 6
Hi Everyone,
I connected two switches together  via below config
Switch A
int gi0/1
switch mode access
switchport access vlan 10
Switch B
int gi0/1
switch mode access
They work fine with above config.
I did the Test below
However when i changed Config of Switch B  as below
int gi0/1
switch mode access
switchport port-security
Switch B is unable to ping its default gateway.
Also Switch B is not reachable via SSH.
Port is up up and in STP forwarding state.
Switch B can see Switch A as a neighbour.
I know that switchport port-security we use only when connecting to PC.
S does this mean that  on above scenario layer 1 and layer 2 are up but layers beyond 3 and above are not reachable like ping,ssh etc??
MAhesh
I was just trying to see how the switches behave with this config.
Nothing much just  exploring the options in the network world
Ideally if you want to connect two switches together in Layer 2, Dot1Q trunking is the way to go.  You do not want to put port security because it is useless.
7 Replies 7
Leo Laohoo
Mahesh,
Why do you want to enable port security on a switch-to-switch link?
Hi Leo,
Mahesh
So seems there is no use to try this experiment.
Mahesh
I disagree, Mahesh.
You learnt something from all of this, didn't you? If you don't try and "experiment" things, then you won't learn. You learn from your mistakes. Now THAT means a lot.
Sent from Cisco Technical Support Nintendo App
Hi Leo,
yes you are right if i see broader picture i learn something from this.
I agree with what you said.
MAhesh
Thanks for the ratings, Mahesh.
