cisco 2511 reverse forwarding with connection failed?
chuang123
hi,
I am try to set up my ccie lab.
with 5xrouter, 4xswitches.
and the problem is from time to time, my devices console will not be reachable.
I can only access my access server, but none of my router can be reach. it show up a error of remote connection refused.
can anyone help?
I have very easy configuration on my accesss server only.
2511#sh run
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname 2511
enable password 1234
ip subnet-zero
no ip domain-lookup
ip host R1 2001 1.1.1.1
ip host R2 2002 1.1.1.1
ip host R3 2003 1.1.1.1
ip host R4 2004 1.1.1.1
ip host R5 2005 1.1.1.1
ip host SW1 2006 1.1.1.1
ip host SW2 2007 1.1.1.1
ip host SW3 2008 1.1.1.1
ip host SW4 2009 1.1.1.1
interface Loopback0
ip address 1.1.1.1 255.255.255.0
no ip directed-broadcast
interface Ethernet0
ip address 10.2.1.200 255.255.255.0
interface Serial0
no ip address
interface Serial1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 10.2.1.1
no alias exec s
line con 0
exec-timeout 0 0
logging synchronous
transport input none
line 1 16
exec-timeout 0 0
transport input all
line aux 0
line vty 0 4
password 1234
login
end
2511#connect sw1
Trying SW1 (1.1.1.1, 2006)...
% Connection refused by remote host
2511#
2511#
Collin Clark
Did you try clearing the line?
Sent from Cisco Technical Support Android App
Reza Sharifi
Try adding below commands to all your routers and switches and test again.
config t
line vty 0 4
transport input all
end
wr
