Enable Split Tunnel
rodger rau
Visitor
Cisco 4000 series router.  All traffic is going over DMVPN tunnels back through our main data center.  Would like to route Internet traffic straight out the Internet interface and corporate destined traffic over the tunnels.  I lose access to the site with the below configuration.  Am I missing something?
interface GigabitEthernet0/0/0.52 (inside interface)
 ip address 192.168.52.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
interface GigabitEthernet0/0/1 (outside interface)
 ip address x.x.x.x (ISP IP)
 ip nat outside
ip nat pool internet x.x.x.x (ISP IP) x.x.x.x (ISP IP) netmask 255.255.255.252
ip nat inside source list internet pool internet overload
ip route 0.0.0.0 0.0.0.0 x.x.x.x (ISP gateway ip)
ip access-list extended internet
permit ip 192.168.52.0 0.0.0.255 any
permit ip 192.168.53.0 0.0.0.255 any
15 Replies 15
Georg Pauwen
you need to exclude the traffic that goes to the other side over the tunnel from your NAT. What is the IP address space of the other side(s) ?
10.0.0.0/8
192.168.0.0/16
I'm running IOS-XE and apparently you cannot use a NAT POOL for only 1 IP address.
Restrictions section:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-3s/nat-xe-3s-book/iadnat-addr-consv.html#reference_255FB71880424C21A193DF9BC9B2F957
still not working.. the router doesnt drop.. but its not taking the correct path.  traceroute to google still goes over DMVPN tunnel.  My config sanitized
interface GigabitEthernet0/0/0.52 (inside)
  ip nat inside
interface GigabitEthernet0/0/1 (outside)
 ip nat outside
ip route 0.0.0.0 0.0.0.0 (ISP IP)
I do not see an access list for the DMVPN traffic. Post the full configuration...
Here ya go.. attached config does NOT have the split tunnel config applied that I posted above.
config looks ok as far as I can tell. Can you post the output of 'show ip route' ?
attached..without the split tunnel config changes
as far as I can tell, the problem is with the default route. You have configured:
ip route vrf DMVPN 0.0.0.0 0.0.0.0 x.x.x.x
What is the output of:
ping vrf DMVPN 8.8.8.8
cant ping it.. however, we are blocking ping to Internet
Should I just have the one default route? I have both configured when i have split tunnel configured.
ip route 0.0.0.0 0.0.0.0 (ISP GW IP)
remove(?):
the default route you have comes from an external source, I cannot figure out where it is originating. Are you doing some sort of redistribution ?
D*EX 0.0.0.0/0 [170/26880512] via 10.100.251.1, 02:24:55, Tunnel2
Assuming the configuration you posted is from one of the spokes, can you also post the hub configuration ?
attached
great, thanks. I need to lab this, will get back with you...
