enable STP to specific vlans in 6500 switch
oded-levi
hello!
I have 6500 with this STP configuration:
spanning-tree mode rapid-pvst
no spanning-tree vlan 1-4094
I need to enable STP on vlan 100 and vlan 103.
When I do "spanning-tree vlan 100,103 root primary" and then "show spanning-tree".
I see that STP is not enable on these vlans (100,103).
I tried to do "no spanning-tree vlan 1-99,101,102,104-4094" and it is not work.
There is a way to enable STP on vlans 100,103 without to do "spanning-tree vlan 1-4094"
thanks.
InayathUlla Sharieff
Yes Certienly there is a way to enable STP for each vlan without enabling the cmd 1-4094. Details below
Simple,
You are the steps:
1- Disable STP for vlan 1-4094
Switch(config)#spanning-tree mode rapid-pvst
Switch(config)#no spanning-tree vlan 1-4094
Switch(config)#vlan 100
Switch(config-vlan)#vlan 200
Switch#sh spanning-tree vlan 100
No spanning tree instance exists. >>>>>>NO STP instance.
2- Enable STP for VLans 100 and 200:
Switch# config t
Switch(config)#spanning-tree vlan 100
Switch(config)#spanning-tree vlan 200
VLAN0100
  Spanning tree enabled protocol rstp
  Root ID    Priority    32868
             Address     0007.ECC2.1731
             This bridge is the root
             Hello Time  2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32868  (priority 32768 sys-id-ext 100)
Switch#sh spanning-tree vlan 200
VLAN0100
REgards
Inayath
*PLZ RATE ALL USEFULL POSTS AND MARK THE THREAD AS ANSWERED IF IT RESOLVES YOUR QUERY.
