Enabling Jumbo Frames per Interface or Vlan on 9400
mumbles202
Level 5
Level 5
Is there a way to enable jumbo frames on a per interface or per vlan basis on the Catalyst 9400 like you can on a N7K? I know you can enable it system wide, but wanted to see if possible to limit it to a single vlan.
luis_cordova
Hi @mumbles202 ,
According to this guide, it is not possible:
Restrictions for System MTU
When configuring the system MTU values, follow these guidelines:
  • The device does not support the MTU on a per-interface basis.
I leave the link of the guide:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-9/configuration_guide/int_hw/b_169_int_and_hw_9400_cg/configuring_system_mtu.html
I hope it's useful for you
luis_cordova
Hi @mumbles202 ,
Thanks for confirming. That's what I had come to find but was hoping perhaps I might have missed something.
