encapsulation dot1q
mguzman4158
Hi All,
I'm trying to be able to trunk a subinterface of a router (router on a stick) and I'm having a tough time understanding what IOS and type of router that will support this command. I've tried in one 2611 router but the command is not available, but I can't figure out which IOS I need in oder to do that. Any help would be greatly appreciate it.
Cheers!
Kerem Gursu
Hi Mauricio,
You can select your software from Software Advisor tool by identifying your hardware and matching it with the feature that you want.
You can use this link to reach to the related web page.
http://tools.cisco.com/Support/Fusion/FusionHCHome.do?mySession=6527746&myStep=2
Hope to help,
Kerem
ansalaza
Output taken from Command Lookup Tool:
"encapsulation dot1q"
12.0(1)T - This command was introduced.
Supported Platforms
•Cisco 2600 series
•Cisco 3600 series
•Cisco 4000-m series
•Cisco 7100 series
•Cisco 7200 series
•Cisco 7500 series
This document seems to answer your question:
Bridging Between IEEE 802.1Q VLANs
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t3/feature/guide/dtbridge.html#wp1023787
Hope this helps!
Kerem Gursu
Hi Mauricio,
Hope to help,
Kerem
Jon Marshall
You need a minimum feature set of IP Plus so if you have IP Base the command will not be available.
Jon
