Entry level backbone switch
fred2k3
We're upgrading our comms cabinet, and are upgrading our old 10/100 switches with 7 Cisco Catalyst 2960X-48TS-L switches.
I want to get 2 backbone switches to connect these 7 Catalyst 2960X switches to, but I'm struggling to know where to start.  All I really want is a couple of stand-alone switches with a high throughput / decent backplane speeds to handle the access switches.  12 ports would sufficient if such a model exists, and I won't be stacking and of the switches.
  • Any suggestions on what switch would fit the bill please?
  • Also, is there somewhere you can compare the backplane speeds of different Cisco switches?
Yes you could consider Cisco 3650 with 24 ports but take in consideration you could have SFP port limitation to 4 or 8 depending of the model, the rest will be Ethernet ports, below you will find the table:
https://www.cisco.com/c/en/us/products/switches/catalyst-3650-series-switches/models-comparison.html
You could consider this model: WS-C3650-24TS
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Hi Fred,
You could consider Cisco 3850-12s-s model. It includes 12 SFP ports and expandible to 16 SFP ports.
https://www.cisco.com/c/en/us/support/switches/catalyst-3850-12s-s-switch/model.html
This link can also be useful: https://www.cisco.com/c/dam/assets/prod/switches/cisco-switch-selector-how-to/index.html
There was other model: Cisco 3750G-12 but it is EoL now.
Hope it is useful
Thank you Julio,
I have taken a look at these but I think they may be slightly overkill / out of budget for this project.  Our supplier has recommended the 3650 series, so I think we use a couple of those to host the servers and aggregate the remaining client switches (the 2960s).
Is there anywhere a table which compares all the different series of Cisco switches?  I feel there's so many and it gets really confusing, most of all because I don't understand the intended usage for them.
Hope it is useful
