How to capture data-plane traffic on a cisco 3000 series switch
larrycotton
I have a nexus 3548x switch.
I'd like to capture packets (and write to buffer or file) on the switch, so that I can look at an analyze the traffic that goes in and/or out of the interface. On ios you can do this using 'monitor capture' commands. However these commands do not seem to be available on the nexus.
Does anyone know how I can do the equivalent on the nexus ?
My searches for how to do this have been sending me in circles. There is a lot of documentation about ethanalyzer, but that seems to be designed to capture control-plane traffic and I'm looking to capture data-plane traffic on a particular interface.
Some documentation suggests you can do this by replicating data-plane traffic using ACL or SPAN and view it using ethanalyzer on the sup-eth0 (inband) interface. However the switch I have does not seem to provide "sup-eth0" ?
# ethanalyzer local interface ?
  inbound-hi   Inbound(high priority) interface
  inbound-low  Inbound(low priority) interface
  mgmt         Management interface
Anyone know how can I capture data-plane traffic on a nexus 3548 switch ?
balaji.bandi
The command looking under monitor session.
Example :
CORESW2(config)# monitor session 1
CORESW2(config-monitor)# source interface ?
ethernet Ethernet IEEE 802.3z
port-channel Port Channel interface
sup-eth Ethernet Inband interface
BB
BB
Thank you for the reply.
Do you know how I would capture those packets ? I was hoping to use ethanalyzer, but it does not give me the inband option.
Can I capture to a buffer/file in pcap format ? Or do I have to somehow log then, then parse the log files ?
