%ENVIRONMENTAL-5-SENSOROK: Temp: Inlet_A, Location: Switch1-R0, State: normal
Genesis Cisco
I am getting this message:
Syslog message generated from device HQ11-COR-11.253: Jan 22 15:46:06 10.255.255.249 1700: .Jan 22 15:45:39:
Anyone knows what does that means and how to fix it?
Thanks and Regards
this is an informational message telling you that the temperature of the sensor is in the normal range. As far as I recall, the Catalyst has a number of sensors placed close to the usually hottest (e.g. the CPU) locations.
Check if you have the command 'snmp-server enable traps envmon temperature' configured on the switch, as the default is that environemental traps are disabled.
Genesis Cisco
Device:C9500-48Y4C
Version 16.12.04
Hi Georg
Got it!!
Thank you very much~
