Restrict communication between ports in the layer 3 switch
WangSteven02215
Hi, I have no expertise on the network. I always appreciate your taking the time to answer my question.
We will connect independent systems (System A and B) using the L3 Switch (Catalyst 9300).
and send the syslog to the cyber security operation center like attached picture.
* System A and B consist of L2 Switch (Catalyst 2960).
In order to prevent access from each system to another system, we would like to ensure that coming data through Port 1~3 is transferred to only port 4. Is it possible to implement this function by changing the settings of the Catalyst 9300?
6 Replies 6
balaji.bandi
Question is the Cat 9300 Only for send the Syslog to the cybersecurity operation center?
You can have ACL deployed on Cat 9300 - and Allow the source of the network A and B to only to communicate to Syslog server IP.
so they can not communicate with each other network IP address range.
BB
Thank you for your reply.
Yes, Cat 9300 transmits only syslog to cybersecurity operation center.
I assume System A and System B are on different subnets ? And the layer 3 switch is doing the inter-Vlan routing ?
You can use a simple access list to keep both systems from communicating with each other. The configuration would look something like below:
interface GigabitEthernet0/1
description Port 1 Link to System A
switchport mode access
switchport access vlan 10
interface GigabitEthernet0/2
description Port 2 Link to System B
switchport access vlan 20
interface GigabitEthernet0/3
description Port 3 Link to System B
interface GigabitEthernet0/4
description Port 4 Link to Syslog
no switchport
ip address 172.16.1.1 255.255.255.0
access-list 101 deny 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 101 permit 192.168.10.0 0.0.0.255 any
interface Vlan 10
ip address 192.168.10.1 255.255.255.0
ip access-group 101 in
interface Vlan 20
ip address 192.168.20.1 255.255.255.0
use VRF if you can, VRF separate the traffic.
Just to add a note - On Cat 9K - VRF needs Network Advantage License.
BB
stopher
Hi Wang,
Simply put, a layer 3 switch combines the functionality of a switch and a router. It acts as a switch to connect devices that are on the same subnet or virtual LAN at lightning speeds and has IP routing intelligence built into it to double up as a router.
