Equivaliant command for Show Logging Buffer 1023
mtgrech
Community Member
In CatOS you could enter the command "Show logging buffer 1023" to see an activity log in Catalyst switches running CatOS. Is there an equivaliant command for IOS switches? Thank you.
2 Accepted Solutions
ankbhasi
Hi Friend,
Have you tried "sh log"?Should work.
Ankur
sachinraja
Level 11
Level 11
ankbhasi
Hi Friend,
Ankur
sachinraja
Level 11
Level 11
hello,
you just need to use a Show logging command... refer to the following URL:
http://cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00807743e8.html
Raj
