Erased Flash - Need to Load Image
4bsmith
I accidentally erased the Flash directory on my C3560 switch and need to load a new image on it from which to boot normally.  Sure could use some helpful advice.
Found the following on TechRepublic. Thanks to ernirofori:
First of all you need to get the ios image in .bin format on the PC connected to the switch by hyperterminal console.
At the switch: prompt make sure there is enough space in flash memory by doing dir flash:
then issue the following command to put the switch to listen for xmodem transfers:
copy xmodem: flash:flash_filename
now  from the "transfer" dropdown menu on the hyperterminal, select "send  file" and choose "xmodem" in the subsequent dialog box and browse for  the flash_filename (the downloaded IOS bn file) and send.
The process takes a while but it works...
How does one change the baud rate back to 9600 from the Switch# prompt?
You've got two ways to set the baud rate back.
From ROMmon, use the command "unset BAUD".  The second one is to use the Reza's latest post.
7 Replies 7
Reza Sharifi
Did you reboot the switch after erasing the image?.  If you have not, simply load an image from a TFTP server.
If you have, then there in no image and you have to use Xmodem to load a new image.
Have a look at this link for instruction
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Oh, I went all the way and rebooted. I’m using XMODEM right now. Thank you for the correct answer, sir.
Bill Smith
Senior Network Engineer
North Country HealthCare
928-522-2444 Phone (2552)
928-522-2484 Fax
928-699-8554 Cell
wsmith@northcountryhealthcare.org
Unless you start with the command "set BAUD=115200" the entire process will take approximately 4 hours.
By setting your XMODEM baud rate higher, the time to upload the BIN file will be approximately 45 minutes.
Got it to 115200, but didn't change it back before the switch booted to the image.  How does one change the baud rate back to 9600 from the Switch# prompt?
Bill,
Here are the commands to change it to 9600
C3750-E#config t
Enter configuration commands, one per line.  End with CNTL/Z.
C3750-E(config)#line con 0
C3750-E(config-line)#speed 9600
verify that it is 9600 by issuing this command:
sh line con 0
Please rate if helpful
Thanks for the rating.
