Err disable commands are not working for my catalyst 2960 switch.
Invader12
iOS release version is 12.2(25)Fx. Kindly provide a fix.Screenshot (505).png
Hello
This is from Packet tracer not from real hardware correct?- if so i would this is down to the  PT software, it doesnt support a lot of features the real hardware would be able to.
Kind Regards
Paul
6 Replies 6
Mark Elsen
 - Could you give an example of what you tried and the outcome ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I tried errdisable commands to fix one of  the switch ports but the none of the commands are working. I am doing it in cisco packet tracer.
Hello
show errdisable recovery
show sdm prefer
Kind Regards
Paul
Hi Paul, thanks for the reply. Below are the command results.
Hello
Kind Regards
Paul
Leo Laohoo
12.2(25)FX?   Are you kidding me?
That is the original IOS from the factory -- An INTERIM IOS version.  It is not meant to be used in production because it has extremely limited use.  Might work with the-most-basic Layer 2 function but that is where it stops.
Fix is to upgrade the IOS version to something more recent.
