err-disable recovery
Azeem Dawood
Dear Experts,
I need an opinion from you that, as you know error detection is enabled by default for all the error types so how safe it is to enable err recovery for all the detectable errors in the network..
will it increase cpu and memory processing????
Azeem
Peter Paluch
Azeem,
It is very dangerous - not because of CPU and memory consumption (those are negligible), but rather because a condition that leads to err-disabling a port is always a cause for concern. Simply reactivating an err-disabled interface automatically may put your network in the precisely same dangerous situation that was actually prevented by err-disabling the interface in the first place.
Therefore, automatic err-disable recovery has to be used very cautiously.
Best regards,
Peter
Thanks for the reply,
But how can you find out the reason for the port which goes to error disable..
regards,
Azeem
Hi Azeem,
First and foremost, the show int status err-disable command - this command will tell you what ports are err-disabled and what is the reason. In addition, an err-disabling of a port is always logged, so show logging and optionally Syslog etc. can also provide a clue.
Best regards,
Peter
