Inter VLAN Routing confusion
m.krautler
***Disclaimer*** I am studying for my CCENT and consider myself a complete novice. I have no idea what I'm doing but really want to figure this out. I hope that my excitement overcomes my incompetence. ***Disclaimer***
That being said, I have a cable modem that I plug a NetGear WNDR3700 Wireless Router into. I plugged a Catalyst 3560 8-port switch into that and recently got a used 2611 Router from a friend. I live with roomates & I don't want to bring down the entire house so I want to see if I can put the router on it's own VLAN from the switch in order to not cause a disruption in service. I configured VLANs on Switch port 1 (VLAN10) & 2 (VLAN20) and am trying to configure intervlan rounting between them. I have a maintenance vlan (VLAN1) for using Putty (Telnet) to get into the switch that is on 192.168.1.98. I have assigned IP Addresses to the VLANs (VLAN10 192.168.2.1) (VLAN20 192.168.3.1) but I do not know how to get them to "speak" to each other in order for both of them to communicate / route.
What I would like to do is plug the 2611 Router into 1 of the VLANs for testing purposes and my main PC into the other VLAN. How do I do that? I have included my running-config & VLAN info if that helps.
RUNNING CONFIG:
Current configuration : 1198 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname catalyst3560
enable secret 5 $1$krHA$********6isz0uJy.
enable password m******3
no aaa new-model
clock timezone UTC -5
clock summer-time UTC recurring
system mtu routing 1500
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface GigabitEthernet0/1
interface Vlan1
ip address 192.168.1.98 255.255.255.0
interface Vlan10
ip address 192.168.2.1 255.255.255.0
interface Vlan20
ip address 192.168.3.1 255.255.255.0
ip default-gateway 192.168.1.1
ip classless
ip http server
control-plane
line con 0
line vty 0 4
password m*******3
login
length 0
line vty 5 15
password m*******3
login
end
VLAN INFO:
VLAN Name Status Ports
1 default active Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Gi0/1
10 home-external active Fa0/1
20 home-router2611 active Fa0/2
99 VLAN0099 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
20 enet 100020 1500 - - - - - 0 0
99 enet 100099 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
I really hope someone will please help me, I am really excited to see if this can work so I can start my Routing section for the CCENT. Thank you so much in advance, I really appreaciate any help that can be given.
Thank you,
Mark
Elton Babcock
Plug the router into a port in VLAN 1.
On the router put in the following commands.
Interface FastEthernet 0/0
IP address 192.168.1.97 255.255.255.0
IP route 0.0.0.0 0.0.0.0 192.168.1.98
This will make the router manageable from any of the networks on the 3560.
You will still need to setup the router to accept telnet or ssh and configure an enable secret.
