err-disable state
N. Deepak
Community Member
there is any reasons for switch port sfp module going to err-disable state
Which is the model number of the SFP you are using?
The following error suggests the switch does not support that module, is it a 3rd party one?
%PM-4-ERR_DISABLE: gbic-invalid error detected on Gi0/1, putting Gi0/1 in err-disable state
I 'think' Catalyst switches can have problems with third party SFP's so it may be worth doing the following to make the SFP work:
no errdisable detect cause gbic-invalid
service unsupported-transceiver
9 Replies 9
John Blakley
Can you post "show errdisable cause"?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
hope you can help me
facing the same issue in Cisco WS-C3560-48TS-S
LQZNL-OFFICE-SW#show errdisable d
ALQZNL-OFFICE-SW#show errdisable detect
ErrDisable Reason Detection Mode
arp-inspection Enabled port
bpduguard Enabled port
channel-misconfig Enabled port
community-limit Enabled port
dhcp-rate-limit Enabled port
dtp-flap Enabled port
gbic-invalid Disabled
inline-power Enabled port
invalid-policy Enabled port
l2ptguard Enabled port
link-flap Enabled port
loopback Enabled port
lsgroup Enabled port
mac-limit Enabled port
pagp-flap Enabled port
port-mode-failure Enabled port
psecure-violation Enabled port/vlan
security-violation Enabled port
sfp-config-mismatch Enabled port
small-frame Enabled port
storm-control Enabled port
udld Enabled port
vmps Enabled port
swebhard
Community Member
could you paste the logs ? , sh log
the reason must be there itself
for example:
%PM-SP-4-ERR_DISABLE: udld error detected on Gix/y, putting Gi x/y in err-disable state
, so here the reason would be udld .
1 has bad crc
%LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
%PM-4-ERR_RECOVER: Attempting to recover from gbic-invalid err-disable state on Gi0/1
%GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port Gi0/1 has bad crc
%LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan10, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
%LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
%LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan10, changed state to up
%LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
%LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
Hi devils,
yes  your right,
im using non cisco tx:1310nm rx:1550nm module.
i changed the gig port in other side switch(Gi3 to Gi4), now its working..
and i used that
command..
Thank you
Thanks for the command post.  This resolve the issue I was having also until we can get a new SFP put in.
I had the same problem, i changed the SFP and that resolved the problem.
This worked for me.
If multiple interfaces are in this state then we have to use this command once on one of the interfaces and simply reset the other interfaces.
