err-disabled bpduguard | Switch to Switch
kakados2000
Hello everybody.
I'm having 2 switches that runs the network.
However, i want to create a seperate VLAN 2000 for port 48 & 52 on switch 1.
The same on switch 2.
Switch1 Port 52 --------------connected-------------Port52 Switch2
When i do this, Port52 on Switch 2 gets in the following state: err-disabled bpduguard
How can i solve this? At the and i just want an independent VLAN with these ports.
Thanks for any hints!
Ivan Shirshin
What is the configuration of a port52 on both switches? Do you have portfast enabled there by any chance?
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Actually I just solved it -  i just created a trunk between 52 and 52 and allowed only VLAN2000 - this did the trick.
Thanks.
Great! thanks for update on that.
Kind Regards,
Ivan
