Erro- Diagnostic Monitoring is not implemented.
HI guys,
can someone please assist me with below error,
sh interface tenGigabitEthernet 2/1/3 transceiver detail
#sh interface tenGigabitEthernet 1/1/3  transceiver detail
when i check interface details for these 10 gig ports these are in down/down status below are the IOS and SFP details:-
IOS Details:-
sh version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.04SE RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 29-Aug-14 22:22 by prod_rel_team
SFP Details:-
NAME: "TenGigabitEthernet1/1/3", DESCR: "SFP-10GBase-CX1"
PID: SFP-H10GB-CU5M     , VID: V03  , SN: MOC1838AC0X
NAME: "TenGigabitEthernet2/1/3", DESCR: "SFP-10GBase-CX1"
PID: SFP-H10GB-CU5M     , VID: V03  , SN: MOC1838AC3Q
InayathUlla Sharieff
Looks like DOM not supported.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/DOM_matrix.html
may i know what should be workaround here? do i need to get a new SFP if yes then which one should do here? its 3850 switch need to have 10 gig uplinks.
or it got to do with IOS version?
Thakns!
I believe the model and SFP is supported. Now need to check :
1- IOS is good as you are running the latest one.
2- what is connected at the other end? Can you try doing the loop test between teh ports?
Catalyst 3850 Series
WS-C3850-24T
WS-C3850-24P
WS-C3850-48T
WS-C3850-48P
WS-C3850-48F
 (With C3850-NM-2-10G or C3850-NM-4-10G uplink modules)
SFP-H10GB-CU1M7
SFP-H10GB-CU3M7
SFP-H10GB-CU5M7
XE 3.2.0SE
Can anyone provide an update to this link please:
I m trying to determine what sfps support the, show interface g1/1 transceiver detail, command
Deena
