Error CDP on POE devices
ariel.quintana
There is a massive problem occurring on my network.
specifically the IP cameras, they began to appear as IEEE PD devices, it does not identify them as Cisco devices and it is not possible to see them by CDP.
I describe some points:
- Occurs only with cisco IP cameras in many different models (2500, 2600, 6000P, 4500, 3620, 3630)
- Other devices like phones, AP or DMP will work properly.
- Occurs in multiple branches with different switch models and IOS (2960, 3560, 3850)
- Occurs in more than 100 different IP cameras
- some IP cameras detect them correctly
- The cameras in IEEE PD, turn on correctly, have ping response, web access and register in VSOM without problems, but it is not possible to see them by CDP.
Regards.
6 Replies 6
Leo Laohoo
Post the complete output to the command "sh version" (remove the hostname).
Is this problem more prevalent with IOS-XE or classic IOS?
ariel.quintana
Hello Leo, Thanks for your comment.
attached show version.
For the example I used a specific case, but as I mentioned this is happening in multiple switches (2960, 3560, 3850) with different IOS (cat3k_caa-universalk9.16.12.07.SPA, cat3k_caa-universalk9.03.07.04E.SPA, cat3k_caa-universalk9.16.03.08.SPA, c3560-ipbasek9-mz.122-55.SE7, c2960-lanlitek9-mz.122-55.SE12, c2960-lanlitek9-mz.150-2.SE11) and with multiple camera models.
Sw3850_PoetaLugones#show ver
Cisco IOS XE Software, Version 16.12.07
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.12.7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Wed 02-Feb-22 07:28 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2022 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 5.08, RELEASE SOFTWARE (P)
Sw3850_PoetaLugones uptime is 2 days, 17 hours, 15 minutes
Uptime for this control processor is 2 days, 17 hours, 18 minutes
System returned to ROM by Power Failure or Unknown
System restarted at 17:31:40 GTM Wed Aug 24 2022
System image file is "flash:packages.conf"
Last reload reason: Power Failure or Unknown
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
ipbasek9 Smart License ipbasek9
None Subscription Smart License None
Smart Licensing Status: UNREGISTERED/EVAL MODE
cisco WS-C3850-24P (MIPS) processor (revision Y0) with 794816K/6147K bytes of memory.
Processor board ID FCW1951D1BA
7 Virtual Ethernet interfaces
112 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
250456K bytes of Crash Files at crashinfo:.
250456K bytes of Crash Files at crashinfo-2:.
250456K bytes of Crash Files at crashinfo-3:.
252000K bytes of Crash Files at crashinfo-4:.
1609272K bytes of Flash at flash:.
1609272K bytes of Flash at flash-2:.
1609272K bytes of Flash at flash-3:.
1611414K bytes of Flash at flash-4:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : 0c:11:67:41:8f:00
Motherboard Assembly Number : 73-15805-04
Motherboard Serial Number : FOC195125WG
Model Revision Number : Y0
Motherboard Revision Number : B0
Model Number : WS-C3850-24P
System Serial Number : FCW1951D1BA
Switch Ports Model SW Version SW Image Mode
* 1 32 WS-C3850-24P 16.12.07 CAT3K_CAA-UNIVERSALK9 INSTALL
2 32 WS-C3850-24P 16.12.07 CAT3K_CAA-UNIVERSALK9 INSTALL
3 32 WS-C3850-24P 16.12.07 CAT3K_CAA-UNIVERSALK9 INSTALL
4 32 WS-C3850-24P 16.12.07 CAT3K_CAA-UNIVERSALK9 INSTALL
Regards.
There is a very long list of PoE, CDP/LLDP bugs affecting switches that are on IOS-XE, like 3650/3850, Catalyst 9k.
Aside from software bugs, 3650/3850, Catalyst 9200/9300 have a hardware design fault:  CSCvj76259 & CSCvd46008.
However, I do not believe this is a switch issue because this is happening to all your Cisco IPTV cameras regardless of IOS version.  I suspect the problem is squarely on the IPTV themselves.
in one port run lldp and check, may be it not support CDP
also can I know the Camera model?
It occurs in different camera models (2600, 4500, 6000P, 3620, 3630).
all are cisco brand, support CDP and this is enabled correctly.
all the cameras were working correctly and were detected by CDP without problems until the failure began to occur.
the bug is spreading through the network regardless of the model of switch, camera or ios.
try activating only LLDP, also only CDP, deactivating both, restarting sw and cameras, updating IOS and the error persists.
regards.
