08-26-2022 09:33 AM
Hello guys
I'm searching to replace our Juniper stack switches to something supports three things in the same time:
- at least 4 100g interfaces (QSFP28) - could be in a expansion module.
- 48 RJ interfaces (1g)
- 48 SFP+ interfaces (10g)
all should be in the same stack.
I tried Juniper datasheets, but seems like there is no option for a switch or (mixed stack) switches that supports all those requirements in the same stack.
Does Cisco switches can provide what we need ?
Solved! Go to Solution.
08-27-2022 02:23 AM - edited 08-27-2022 02:24 AM
@AbedB wrote:
Could a combination of "2x C9300X-24Y" and "C9300X-48HX" be in one stack ?
Yes, C9300X-24Y and C9300X-48HX can be stacked together.
However, I strongly urge you to reconsider using Catalyst switches, particularly those that run on IOS-XE, for server duties. Why? Because IOS-XE leaks like a sieve. Catalyst 9k switches cannot operate straight without crashing every 14 to 24 months.
If you are looking for switches for servers, look at Nexus.
08-26-2022 10:57 AM
I recommend you split into a Cat9500 with fast interfaces and a Cat9300 aggregating the slow ones.
You can also explore using the new Cat9300X family. For example the C9300X-24HX.
08-27-2022 02:06 AM - edited 08-27-2022 02:14 AM
Could a "2x C9300X-24Y" and "C9300X-48HX" be in one stack ?
And then maybe I will add modular uplink: C9300X-NM-4C for 100G ports
Could this be possible ?
08-26-2022 11:02 AM
Cat 9500 support - but limited 2 Two switches on Stackwise virtual per domain, you can create another SVL (if you like more)
Cat 9600 is the chassis (which can handle more cards and more throughputs)
Cat 9300 is normal standard stacking (required same family of Cat 9300 to stack)
we are not sure your definition of mixed stack ?
=====️ Preenayamo Vasudevam ️=====
08-27-2022 02:08 AM - edited 08-27-2022 02:15 AM
Actually I came from Juniper side, they have there a mixed virtual chassis, means mixed stack, means you can combine different switches platforms in one stack.
And then maybe if I add modular uplink: C9300X-NM-4C for 100G ports for each switch in the stack
08-27-2022 02:40 AM
yes that is possible, check to stack architecture and requirements for stacking :
08-26-2022 07:00 PM
Please provide more information about the requirement.
What are the downstream clients, are they PC, VoIP, or servers?
Provide a network diagram to this setup?
C9500-48Y4C can support 4 x 100 Gbps optics and 48 SFP+ optics, however, the 9500 can only support VSS (2 units only).
If there is a need to go to a very "dense" optics ports, then the options are to go down the Catalyst 9600 with Sup 1 (Sup 2 does not support VSS -- Go figure!) or Nexus.
08-27-2022 02:14 AM
C9300X-48HX is only 48-port mGIG copper ports with uPoE.
What about the other requirement of a 48-port SFP+ switch?
08-27-2022 02:18 AM - edited 08-27-2022 02:22 AM
Hi Leo
I just edited my reply few seconds before you answered
And then maybe if I add modular uplink: C9300X-NM-4C for 100G ports for each switch in the stack. Could this be possible ?
08-27-2022 02:17 AM
There is no much in a topology
It is a stack of switches which provide uplinks for, UCSs, ESXi servers, emc storage ...
There is no VoIP neither PCs
08-27-2022 02:29 AM - edited 08-27-2022 03:07 AM
I appreciate your answer ! That's new to me an I will consider it.
Regarding Nexus, Could a combination of 93108TC-EX + 93180YC-EX be in one stack. If yes, then I think this could be a very good solution. as it has a combination of copper and sfp and QSFP28 ports.
Edit#2:
Acoording to some articles I read now, it is not stacking in Nexus, it is vPC, but the same logic. But they cannot be different models in one vPC.
08-27-2022 06:06 AM - edited 08-27-2022 06:06 AM
These are DC switches, so there is no stacking here. as you mentioned the technology is used here vPC.
