- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-13-2022 12:04 PM
I have a few of these switch that were ios wiped for security reasons and I am re-loading the 1st unit
not sure what the problem is, I am a noob but thinking either the ios I downloaded got corrupted or was corrupted when transferring over via xmodem, or the bootloader needs some kind of update? or maybe I have the wrong ios?
exact model is: ws-c3750g-48ts-s v04
here is the specific issue, I realize it is still initially looking for the original ios but that does not matter as it will skip right to the new ios and should continue to boot but it does not and errors out.
switch: boot
Loading "flash:/c3750-ipbasek9-mz.122-58.SE2/c3750-ipbasek9-mz.122-58.SE2.bin"..
.flash:/c3750-ipbasek9-mz.122-58.SE2/c3750-ipbasek9-mz.122-58.SE2.bin: no such f
ile or directory
Error loading "flash:/c3750-ipbasek9-mz.122-58.SE2/c3750-ipbasek9-mz.122-58.SE2.
bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3750e-universalk9-mz.152-4.E10.bin"...Bootable image segment 1
address range [0x3c00000, 0x5bfa6bc] not in range [0x0, 0x557fffc].
Error loading "flash:/c3750e-universalk9-mz.152-4.E10.bin"
Boot process failed...
switch:
switch: dir flash:
Directory of flash:/
2 drwx 64 <date> lost+found
3 -rwx 25549824 <date> c3750e-universalk9-mz.152-4.E10.bin
3857920 bytes available (28656128 bytes used)
switch:
Solved! Go to Solution.
- Labels:
Catalyst 3000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-13-2022 02:09 PM
"or maybe I have the wrong ios?"
Looks to me that's the issue. You're trying to load an 3750E IOS on a 3750G model. (NB: I recall, the 3750 and 3750G share an IOS as does the 3750E and 3750X.)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-13-2022 04:21 PM - edited 06-13-2022 04:30 PM
@doubeleive wrote:3 -rwx 25549824 <date> c3750e-universalk9-mz.152-4.E10.bin
The IOS file is for a 3750E/X.
There are two "dead giveaways": Firstly, the prefix said so. Next, the "universal" in the middle.
@doubeleive wrote:
when I look under 3750 it only shows the 3750v2 line, I can't find a link for any that say "3750g", but now looking at the release notes under the 3750v2 it does mention a few 3750g models
3750/3750G/3750v2 IOS files are the same.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-13-2022 02:09 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-13-2022 02:59 PM
when I look under 3750 it only shows the 3750v2 line, I can't find a link for any that say "3750g", but now looking at the release notes under the 3750v2 it does mention a few 3750g models, I guess I will try that and see, I think you may be correct the ios under 3750 also say's ipbase.xxxxx which looks like what these had previously. thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-13-2022 05:29 PM
thank you, gentlemen c3750-ipbasek9-mz.122-55.SE12.bin resolved the issue
