error message for switch 2960-s
abdullah7
Unable to play video. Please try again later.
(view in My Videos)
when i start the switch and after booting.
a message start appearing over and over. and never end. I can't do anything.
*Mar 1 01:12:08.673: EMAC phy access error, retrying......
*Mar 1 01:12:08.673: -Traceback= 13A7C60 13A7D18 13AE394 13A965C 13AB2CC 18769A8 186D420
*Mar 1 01:12:08.872: EMAC phy access error, retrying......
*Mar 1 01:12:08.872: -Traceback= 13A7C60 13A7CEC 13AE394 13A965C 13AB2CC 18769A8 186D420
*Mar 1 01:12:08.872: -Traceback= 13A7C60 13A7D18 13AE394 13A965C 13AB2CC 18769A8 186D420
*Mar 1 01:12:09.077: EMAC phy access error, retrying......
*Mar 1 01:12:09.077: -Traceback= 13A7C60 13A7CEC 13AE394 13A965C 13AB2CC 18769A8 186D420
please watch the attached video
7 Replies 7
Reza Sharifi
Tracebacks errors are usually a sign of software bug. So, upgrade to a different version and test again.
Mark Malone
try change the software , hold the mode button break into rommon mode , check the flash see what images are stored in it , if theres 2 boot the second image if not load another image onto the switch and set that to boot
That alert can be a forced software crash the image maybe  corrupted and its just spinning out during boot
to go for the new image from rommon mode
i did the recovery process through this link as Cisco said
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
but still same problem
If you added a new image thats verified md5 and not corrupted and still not booting correctly you may have a hardware issue , contact your support vendor or cisco and get it replaced through RMA process
i fixed the problem. in entered to initial configuration while error message appearing and delete all previous configuration and now it is working great
thanks all
i install a new and updated ios and boot from it, but still same problem
