Error on Cisco 6500 Switch
lalit
Can anyone explain me the below error details. I found this error on Cisco 6500 Switch..
%UTIL-3-TREE: Data structure error--attempt to remove an unthreaded node "
Thanks & Regds,
Lalit
sdheer
Hi Lalit,
There are many bugs related to this error message.
Do paste the " show version " output of the switch here.
Also let me know if you are getting any tracebacks along with these messages.
Swati
Hi Swathi,
Thanks for the reply.
I got below bug details.
Cisco Catalyst 6500 Series Switches
CSCsz93221 Bug Details
MU:During link-flap error recovery, active Sup5 detected data structure
Symptom:
A Cisco switch may report the following error message:
%UTIL-3-TREE: Data structure error--attempt to remove an unthreaded node from a tree
Conditions:
This issue is seen when dot1x is configured on the device.
Workaround:
There is no known workaround
Thanks & Regds,
Lalit
