Error : pre and post compression image sizes disagree
kian_hong2000
I received this error when booting the new IOS c3745-adventerprisek9-mz.124-15.T14.bin from slot0.
I don't have this error when loading the inital IOS c3745-ipbase-mz.123-26.bin from flash. I tried to re-download the new IOS from cisco but the error still occurred. I also tried to boot the IOS from flash. But it failed. Not sure how to recover from this.
System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2002 by cisco Systems, Inc.
c3745 processor with 518144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x80008000, size: 0xac80
program load complete, entry point: 0x80008000, size: 0x2c5ac7c
Self decompressing the image : ##################################################################################################### [OK]
*** System received a Software forced crash ***
signal= 0x17, code= 0x8, context= 0x80020d00
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041a803
program load complete, entry point: 0x80008000, size: 0xca00
program load complete, entry point: 0x80008000, size: 0xb2c410
Self decompressing the image : ###################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
0002F7          0X005F3C00 C3745 Mainboard
                0X00280000 OIR memory
00030B          0X00016804 Virtual Private Network (VPN) Module
                0X000F3BB0 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X00B8EFB4
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 12Mb.
Using 2 percent iomem. [12Mb/506Mb]
No Need of Download TDM FPGA as EADI...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 3700 Software (C3745-IPBASE-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 17:42 by dchih
cisco 3745 (R7000) processor (revision 2.0) with 505856K/12288K bytes of memory.
Processor board ID FHK1005F0JP
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31360K bytes of ATA System CompactFlash (Read/Write)
125184K bytes of ATA Slot0 CompactFlash (Read/Write)
Router#sh ver
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes
System returned to ROM by reload
System image file is "flash:c3745-ipbase-mz.123-26.bin"
Bridging software.
Pawan Gupta
Hi Kian,
This issue generally comes up due to a harware issue wherein the device is not able to read the flash properly. You can try using a spare flash if that resolves the issue. However, you may need to replace the entire router. Sorry to break it to you...
Regads,
Pawan
"If this post answers your question, please click the "Correct Answer" button"
