05-13-2024 01:01 AM
One of my clients has a Network Challenge, they are pointing fingers to our installed solutions that has been working without issues for months. I got their switches log files, they have 6 switches, 5 of them were throwing mainly this error “%SW_MATM-4-MACFLAP_NOTIF” among other erros, switch number 6 had totally different type of errors, client has multiple vlans across multiple switches. I strongly see the issue from their Network Design and Configuration and I want to help them out.
Below is the log file from 2 switches out of the 6, appreciate an input on how to guide the client to solve their issue.
Client is pointing to our solution as it was the last change made to the network, however our argument is that our solution worked for months without issue till this network problem happened, so the network change happened from their side as we dont have access to our solution after installing.
Device: U1HE_Access_Switch, Date Range: 04/09/2024 12:00 AM - 04/09/2024 11:45 PM, Business Hours: No Business Hours | ||||
Date | Source | Syslog Type | Payload | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>208: Apr 9 17:52:29.970 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13 changed state to down</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>209: Apr 9 17:52:31.977 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13 changed state to up</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>210: Apr 9 18:44:53.947 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a26 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>211: Apr 9 18:44:53.947 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a28 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>212: Apr 9 18:44:53.947 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a27 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>213: Apr 9 18:44:53.947 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a23 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>214: Apr 9 18:44:54.052 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>215: Apr 9 18:44:54.052 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>216: Apr 9 18:44:54.150 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>217: Apr 9 18:44:54.150 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>218: Apr 9 18:44:54.157 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>219: Apr 9 18:44:54.160 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>220: Apr 9 18:44:54.167 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>221: Apr 9 18:44:54.167 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>222: Apr 9 18:56:19.925 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a24 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>223: Apr 9 18:56:19.925 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a27 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>224: Apr 9 18:56:19.985 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>225: Apr 9 18:56:19.985 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>226: Apr 9 18:56:20.044 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a28 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>227: Apr 9 18:56:20.044 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a26 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>228: Apr 9 18:56:20.100 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>229: Apr 9 18:56:20.100 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>230: Apr 9 18:56:20.104 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a23 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>231: Apr 9 18:56:20.153 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>232: Apr 9 18:56:20.153 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>233: Apr 9 18:56:20.177 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000a.8d02.6a25 in vlan 61 is flapping between port Gi1/0/25 and port Gi1/0/13</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>234: Apr 9 18:56:20.212 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>235: Apr 9 18:56:20.212 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>236: Apr 9 18:56:20.222 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>237: Apr 9 18:56:20.222 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>238: Apr 9 18:56:20.331 UTC: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: port</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>239: Apr 9 18:56:20.331 UTC: %HA_EM-3-FMPD_ERROR: Error executing applet TAC statement 130</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>246: Apr 9 19:33:59.117 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13 changed state to down</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>247: Apr 9 19:34:00.120 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/13 changed state to down</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>248: Apr 9 19:49:12.986 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/26 changed state to up</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>249: Apr 9 19:49:14.999 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26 changed state to up</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>250: Apr 9 20:05:06.942 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26 changed state to down</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>251: Apr 9 20:05:07.952 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/26 changed state to down</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>252: Apr 9 20:13:48.095 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/26 changed state to up</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>253: Apr 9 20:13:50.108 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26 changed state to up</attr></LogEntry> | |
Tuesday, 9 April 2024 | U1HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>254: Apr 9 20:24:34.989 UTC: %SYS-5-CONFIG_I: Configured from console by admin on vty1 (192.168.5.41)</attr></LogEntry> |
Log file from second switch
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>348: Apr 9 08:26:50.739 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>349: Apr 9 08:26:51.745 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>350: Apr 9 08:26:54.457 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>351: Apr 9 08:26:55.461 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>352: Apr 9 08:27:12.738 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>353: Apr 9 08:27:13.744 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>354: Apr 9 08:27:20.399 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>355: Apr 9 08:27:21.402 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>356: Apr 9 08:43:12.915 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/16 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>357: Apr 9 08:43:13.918 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>358: Apr 9 08:43:17.193 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>359: Apr 9 08:43:18.196 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>360: Apr 9 08:43:31.042 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/16 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>361: Apr 9 08:43:32.041 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>362: Apr 9 08:43:34.837 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>363: Apr 9 08:43:35.841 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>364: Apr 9 11:25:38.062 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>365: Apr 9 11:25:39.069 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>366: Apr 9 11:25:41.781 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>367: Apr 9 11:25:42.784 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>368: Apr 9 12:24:04.633 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/11 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>369: Apr 9 12:24:05.639 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/11 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>370: Apr 9 12:24:29.442 UTC: %PM-4-ERR_DISABLE: link-flap error detected on Gi1/0/11 putting Gi1/0/11 in err-disable state</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>371: Apr 9 12:52:37.321 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>372: Apr 9 12:52:38.327 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>373: Apr 9 12:52:41.005 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>374: Apr 9 12:52:42.008 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>375: Apr 9 12:52:54.766 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>376: Apr 9 12:52:55.772 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>377: Apr 9 12:52:58.443 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>378: Apr 9 12:52:59.446 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>379: Apr 9 13:24:29.441 UTC: %PM-4-ERR_RECOVER: Attempting to recover from link-flap err-disable state on Gi1/0/11</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>380: Apr 9 13:24:46.281 UTC: %PM-4-ERR_DISABLE: link-flap error detected on Gi1/0/11 putting Gi1/0/11 in err-disable state</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><188>381: Apr 9 14:24:46.276 UTC: %PM-4-ERR_RECOVER: Attempting to recover from link-flap err-disable state on Gi1/0/11</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>382: Apr 9 14:24:51.380 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>383: Apr 9 14:24:52.379 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>384: Apr 9 14:26:32.585 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>385: Apr 9 14:26:33.584 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>386: Apr 9 14:26:36.300 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>387: Apr 9 14:26:37.300 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>388: Apr 9 14:57:02.849 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>389: Apr 9 14:57:03.849 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>390: Apr 9 14:57:06.526 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>391: Apr 9 14:57:07.526 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>392: Apr 9 14:59:49.933 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>393: Apr 9 14:59:50.936 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>394: Apr 9 14:59:53.652 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>395: Apr 9 14:59:54.652 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>19: Apr 9 20:05:06.104 UTC: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=25: Transceiver has been inserted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>20: Apr 9 20:05:06.488 UTC: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=27: Transceiver has been inserted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>21: Apr 9 20:05:06.614 UTC: %LINK-5-CHANGED: Interface Bluetooth0 changed state to administratively down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>22: Apr 9 20:05:07.205 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/7 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>23: Apr 9 20:05:07.208 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/12 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>24: Apr 9 20:05:07.212 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>25: Apr 9 20:05:07.222 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/25 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>26: Apr 9 20:05:07.222 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/27 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>27: Apr 9 20:05:07.523 UTC: %LINK-3-UPDOWN: Interface FastEthernet0 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>28: Apr 9 20:05:07.526 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>29: Apr 9 20:05:08.204 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/7 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>30: Apr 9 20:05:08.204 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>31: Apr 9 20:05:08.208 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>32: Apr 9 20:05:08.208 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>33: Apr 9 20:05:08.211 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>34: Apr 9 20:05:08.211 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>35: Apr 9 20:05:08.211 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>36: Apr 9 20:05:08.229 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>37: Apr 9 20:05:08.428 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/6: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>38: Apr 9 20:05:08.589 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/2: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>39: Apr 9 20:05:09.141 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/5: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>40: Apr 9 20:05:09.228 UTC: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>41: Apr 9 20:05:09.945 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>42: Apr 9 20:05:09.987 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>43: Apr 9 20:05:10.025 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>44: Apr 9 20:05:10.067 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/13 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>45: Apr 9 20:05:10.071 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>46: Apr 9 20:05:10.225 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>47: Apr 9 20:05:10.267 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>48: Apr 9 20:05:10.305 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>49: Apr 9 20:05:10.312 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>50: Apr 9 20:05:10.630 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>51: Apr 9 20:05:10.651 UTC: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>52: Apr 9 20:05:10.665 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/25 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>53: Apr 9 20:05:10.665 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/27 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>54: Apr 9 20:05:11.224 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>55: Apr 9 20:05:11.266 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>56: Apr 9 20:05:11.308 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>57: Apr 9 20:05:11.315 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>58: Apr 9 20:05:11.633 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>59: Apr 9 20:05:13.870 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>60: Apr 9 20:05:14.590 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>61: Apr 9 20:05:14.870 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>62: Apr 9 20:05:15.590 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>63: Apr 9 20:05:17.275 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>64: Apr 9 20:05:18.274 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>65: Apr 9 20:05:23.318 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>66: Apr 9 20:05:24.080 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>67: Apr 9 20:05:24.321 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>68: Apr 9 20:05:25.083 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>69: Apr 9 20:05:29.760 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>70: Apr 9 20:05:30.560 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>71: Apr 9 20:05:30.759 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>72: Apr 9 20:05:31.563 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>26: Apr 9 20:33:37.488 UTC: %LINK-3-UPDOWN: Interface FastEthernet0 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>27: Apr 9 20:33:37.492 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>28: Apr 9 20:33:38.184 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/7 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>29: Apr 9 20:33:38.184 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>30: Apr 9 20:33:38.198 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>31: Apr 9 20:33:38.198 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>32: Apr 9 20:33:38.198 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>33: Apr 9 20:33:38.198 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>34: Apr 9 20:33:38.201 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>35: Apr 9 20:33:38.201 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>36: Apr 9 20:33:38.201 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>37: Apr 9 20:33:38.397 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/2: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>38: Apr 9 20:33:38.397 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/5: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>39: Apr 9 20:33:38.397 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/6: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>40: Apr 9 20:33:39.722 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>41: Apr 9 20:33:39.959 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>42: Apr 9 20:33:39.966 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>43: Apr 9 20:33:40.082 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>44: Apr 9 20:33:40.120 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/13 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>45: Apr 9 20:33:40.162 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>46: Apr 9 20:33:40.242 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>47: Apr 9 20:33:40.249 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>48: Apr 9 20:33:40.319 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>49: Apr 9 20:33:40.763 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>50: Apr 9 20:33:41.284 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>51: Apr 9 20:33:41.284 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>52: Apr 9 20:33:41.347 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>53: Apr 9 20:33:41.574 UTC: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>54: Apr 9 20:33:41.763 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>55: Apr 9 20:33:43.650 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>56: Apr 9 20:33:43.891 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>57: Apr 9 20:33:44.653 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>58: Apr 9 20:33:44.895 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>59: Apr 9 20:33:47.104 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>60: Apr 9 20:33:48.110 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>61: Apr 9 20:33:54.154 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>62: Apr 9 20:33:55.153 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>63: Apr 9 20:33:55.380 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/27 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>64: Apr 9 20:33:57.310 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>65: Apr 9 20:33:57.401 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/27 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>66: Apr 9 20:33:59.320 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>67: Apr 9 20:34:00.791 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>68: Apr 9 20:34:00.910 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>69: Apr 9 20:34:01.798 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>70: Apr 9 20:34:02.920 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>71: Apr 9 20:34:33.853 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>72: Apr 9 20:34:34.933 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>73: Apr 9 20:34:35.855 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>74: Apr 9 20:34:36.935 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>75: Apr 9 20:38:43.193 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/8 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>76: Apr 9 20:38:44.197 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/8 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>77: Apr 9 20:38:48.188 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>78: Apr 9 20:38:49.191 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>79: Apr 9 20:39:02.631 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/8 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>80: Apr 9 20:39:03.630 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/8 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>81: Apr 9 20:39:06.388 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>82: Apr 9 20:39:07.388 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>44: Apr 9 20:57:41.190 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>45: Apr 9 20:57:41.316 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>46: Apr 9 20:57:41.393 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>47: Apr 9 20:57:41.403 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>48: Apr 9 20:57:41.435 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>49: Apr 9 20:57:41.445 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>50: Apr 9 20:57:41.609 UTC: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>51: Apr 9 20:57:42.326 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>52: Apr 9 20:57:42.392 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>53: Apr 9 20:57:42.406 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>54: Apr 9 20:57:42.434 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>55: Apr 9 20:57:44.769 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>56: Apr 9 20:57:45.129 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>57: Apr 9 20:57:45.730 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>58: Apr 9 20:57:45.772 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>59: Apr 9 20:57:46.132 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>60: Apr 9 20:57:47.740 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>61: Apr 9 20:57:48.289 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>62: Apr 9 20:57:49.292 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>63: Apr 9 20:57:50.596 UTC: %USB_CONSOLE-6-MEDIA_USB: Console media-type is USB.</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>64: Apr 9 20:57:54.297 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>65: Apr 9 20:57:56.307 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>66: Apr 9 20:57:58.502 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>67: Apr 9 20:57:58.984 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>68: Apr 9 20:57:59.505 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>69: Apr 9 20:58:00.987 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>70: Apr 9 20:58:01.620 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>71: Apr 9 20:58:02.619 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>72: Apr 9 20:58:04.262 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>73: Apr 9 20:58:06.265 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>74: Apr 9 20:58:15.335 UTC: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>75: Apr 9 20:58:27.586 UTC: %USB_CONSOLE-6-MEDIA_USB: Console media-type is USB.</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>76: Apr 9 20:58:34.468 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>77: Apr 9 20:58:36.467 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>78: Apr 9 20:58:36.747 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>79: Apr 9 20:58:38.750 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>80: Apr 9 20:58:41.504 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>81: Apr 9 20:58:43.507 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>82: Apr 9 20:58:47.226 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/27 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>83: Apr 9 20:58:49.246 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/27 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>84: Apr 9 20:59:00.029 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>85: Apr 9 20:59:01.032 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/9 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>86: Apr 9 20:59:03.828 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>87: Apr 9 20:59:04.828 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>88: Apr 9 20:59:10.585 UTC: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>89: Apr 9 20:59:19.333 UTC: %USB_CONSOLE-6-MEDIA_USB: Console media-type is USB.</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>20: Apr 9 21:07:10.534 UTC: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=27: Transceiver has been inserted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>21: Apr 9 21:07:10.659 UTC: %LINK-5-CHANGED: Interface Bluetooth0 changed state to administratively down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>22: Apr 9 21:07:11.226 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/7 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>23: Apr 9 21:07:11.233 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/12 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>24: Apr 9 21:07:11.240 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/18 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>25: Apr 9 21:07:11.247 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/27 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>26: Apr 9 21:07:11.533 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>27: Apr 9 21:07:11.537 UTC: %LINK-3-UPDOWN: Interface FastEthernet0 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>28: Apr 9 21:07:12.246 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/7 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>29: Apr 9 21:07:12.246 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>30: Apr 9 21:07:12.246 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>31: Apr 9 21:07:12.246 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>32: Apr 9 21:07:12.250 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>33: Apr 9 21:07:12.250 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>34: Apr 9 21:07:12.250 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>35: Apr 9 21:07:12.250 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>36: Apr 9 21:07:12.250 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>37: Apr 9 21:07:12.250 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>38: Apr 9 21:07:12.599 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/2: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>39: Apr 9 21:07:12.599 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/6: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>40: Apr 9 21:07:13.005 UTC: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>41: Apr 9 21:07:13.186 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/5: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>42: Apr 9 21:07:13.270 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>43: Apr 9 21:07:13.990 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>44: Apr 9 21:07:14.032 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>45: Apr 9 21:07:14.148 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/13 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>46: Apr 9 21:07:14.162 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>47: Apr 9 21:07:14.232 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>48: Apr 9 21:07:14.239 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>49: Apr 9 21:07:14.389 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>50: Apr 9 21:07:14.511 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>51: Apr 9 21:07:14.634 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>52: Apr 9 21:07:14.672 UTC: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>53: Apr 9 21:07:14.693 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/27 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>54: Apr 9 21:07:15.392 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>55: Apr 9 21:07:15.511 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>56: Apr 9 21:07:15.637 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>57: Apr 9 21:07:17.954 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>58: Apr 9 21:07:18.712 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>59: Apr 9 21:07:18.954 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>60: Apr 9 21:07:19.712 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>61: Apr 9 21:07:21.156 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>62: Apr 9 21:07:22.159 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>63: Apr 9 21:07:25.658 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>64: Apr 9 21:07:26.661 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/9 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>65: Apr 9 21:07:28.419 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>66: Apr 9 21:07:29.258 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>67: Apr 9 21:07:30.261 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>68: Apr 9 21:07:30.425 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>69: Apr 9 21:07:32.061 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>70: Apr 9 21:07:33.578 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>71: Apr 9 21:07:34.064 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>72: Apr 9 21:07:34.581 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>73: Apr 9 21:07:35.738 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>74: Apr 9 21:07:36.741 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>75: Apr 9 21:08:07.482 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>76: Apr 9 21:08:09.282 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>77: Apr 9 21:08:09.485 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>78: Apr 9 21:08:11.285 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>25: Apr 9 18:33:11.771 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>26: Apr 9 18:33:11.795 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>27: Apr 9 18:33:11.795 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>28: Apr 9 18:33:11.795 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>29: Apr 9 18:33:11.799 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>30: Apr 9 18:33:11.799 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/18 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>31: Apr 9 18:33:11.799 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>32: Apr 9 18:33:12.187 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>33: Apr 9 18:33:12.204 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/2: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>34: Apr 9 18:33:12.424 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/5: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>35: Apr 9 18:33:13.165 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/6: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>36: Apr 9 18:33:13.473 UTC: %USB_CONSOLE-6-MEDIA_USB: Console media-type is USB.</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>37: Apr 9 18:33:13.704 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/8 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>38: Apr 9 18:33:13.714 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>39: Apr 9 18:33:13.746 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/24 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>40: Apr 9 18:33:13.787 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/13 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>41: Apr 9 18:33:13.794 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>42: Apr 9 18:33:13.903 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>43: Apr 9 18:33:13.987 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>44: Apr 9 18:33:14.025 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>45: Apr 9 18:33:14.106 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>46: Apr 9 18:33:14.147 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>47: Apr 9 18:33:14.319 UTC: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>48: Apr 9 18:33:14.906 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>49: Apr 9 18:33:14.990 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/20 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>50: Apr 9 18:33:15.025 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/4 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>51: Apr 9 18:33:15.105 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/9 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>52: Apr 9 18:33:15.147 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/11 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>53: Apr 9 18:33:17.870 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>54: Apr 9 18:33:18.464 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>55: Apr 9 18:33:18.667 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>56: Apr 9 18:33:18.873 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>57: Apr 9 18:33:19.670 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>58: Apr 9 18:33:20.792 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>59: Apr 9 18:33:21.792 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>60: Apr 9 18:33:26.975 UTC: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=50: Transceiver has been inserted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>61: Apr 9 18:33:27.045 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/50 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>62: Apr 9 18:33:27.335 UTC: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=49: Transceiver has been inserted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>63: Apr 9 18:33:28.006 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>64: Apr 9 18:33:28.209 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>65: Apr 9 18:33:30.009 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>66: Apr 9 18:33:31.047 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>67: Apr 9 18:33:31.582 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/50 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>68: Apr 9 18:33:31.970 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>69: Apr 9 18:33:32.973 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>70: Apr 9 18:33:33.057 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>71: Apr 9 18:33:35.015 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>72: Apr 9 18:33:36.014 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>73: Apr 9 18:33:37.377 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>74: Apr 9 18:33:37.790 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>75: Apr 9 18:33:39.611 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>76: Apr 9 18:33:46.490 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>77: Apr 9 18:33:55.511 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>78: Apr 9 18:33:59.048 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/15: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>79: Apr 9 18:33:59.146 UTC: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/15: PD removed</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>80: Apr 9 18:34:00.188 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>81: Apr 9 18:34:01.194 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>82: Apr 9 18:34:03.910 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>83: Apr 9 18:34:04.648 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>84: Apr 9 18:34:04.910 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>85: Apr 9 18:34:08.678 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>86: Apr 9 18:34:10.677 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>87: Apr 9 18:34:13.827 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>88: Apr 9 18:34:13.994 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>89: Apr 9 18:34:15.997 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/6 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>90: Apr 9 18:34:22.631 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>91: Apr 9 18:34:31.869 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>92: Apr 9 18:34:41.251 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>93: Apr 9 18:34:50.234 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>94: Apr 9 18:34:59.234 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>95: Apr 9 18:35:08.553 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>96: Apr 9 18:35:09.451 UTC: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/15: PD removed</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>97: Apr 9 18:35:10.482 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>98: Apr 9 18:35:11.482 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>99: Apr 9 18:35:14.194 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>100: Apr 9 18:35:15.194 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>101: Apr 9 18:35:17.871 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>102: Apr 9 18:35:22.475 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/15: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>103: Apr 9 18:35:23.030 UTC: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/15: PD removed</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>104: Apr 9 18:35:24.082 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>105: Apr 9 18:35:25.082 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>106: Apr 9 18:35:26.809 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error Interface Gi1/0/1: Power Controller reports power Tstart error detected</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>107: Apr 9 18:35:27.756 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>108: Apr 9 18:35:28.756 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>109: Apr 9 18:35:51.993 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/15: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>110: Apr 9 18:35:52.269 UTC: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/15: PD removed</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>111: Apr 9 18:35:53.293 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>112: Apr 9 18:35:54.296 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>113: Apr 9 18:35:56.973 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>114: Apr 9 18:35:57.973 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>115: Apr 9 18:36:09.266 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/15: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>116: Apr 9 18:36:09.735 UTC: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/15: PD removed</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>117: Apr 9 18:36:10.773 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>118: Apr 9 18:36:11.776 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>119: Apr 9 18:36:14.614 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>120: Apr 9 18:36:15.617 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>121: Apr 9 18:37:03.867 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/15: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>122: Apr 9 18:37:03.965 UTC: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/15: PD removed</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>123: Apr 9 18:37:04.992 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>124: Apr 9 18:37:05.992 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>125: Apr 9 18:37:08.792 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>126: Apr 9 18:37:09.791 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>127: Apr 9 18:37:28.352 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/15: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>128: Apr 9 18:37:28.512 UTC: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/15: PD removed</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>129: Apr 9 18:37:29.557 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>130: Apr 9 18:37:30.561 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>131: Apr 9 18:37:33.235 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>132: Apr 9 18:37:34.248 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>133: Apr 9 18:37:36.436 UTC: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/15: Power granted</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>134: Apr 9 18:37:36.954 UTC: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/15: PD removed</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>135: Apr 9 18:37:37.999 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>136: Apr 9 18:37:39.002 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to down</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><187>137: Apr 9 18:37:41.756 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>138: Apr 9 18:37:42.756 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/15 changed state to up</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><190>139: Apr 9 18:39:57.567 UTC: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.</attr></LogEntry> |
Tuesday, 9 April 2024 | U2HE_Access_Switch | Unsolicited | <LogEntry><attr name="Message"><189>140: Apr 9 18:49:14.137 UTC: %SYS-5-CONFIG_I: Configured from console by console</attr></LogEntry> |
05-13-2024 01:45 AM
Addressing the “%SW_MATM-4-MACFLAP_NOTIF” error message specifically, what configuration exists on ports Gi1/0/25 & Gi1/0/13? If these are AP ports, I wouldn't be too concerned about it as it could be a wireless client roaming.
Otherwise, I would advise checking in on the network to ensure they don't have a loop caused by some improper cabling, such as mispatched IP phones (switch port and PC port on back of phone) isn't connected back to the same switch as one example.
