Error when using copy xmodem
sanjaycitizen
switch: flash_init
Initializing Flash...
...The flash is already initialized.
switch: load_helper
switch: copy xmodem: flash:cisco.bin
Begin the Xmodem or Xmodem-1K transfer now...
CC
### Send (x) cisco.bin: NAK on sector
### Send (x) cisco.bin: Retry Count Exceeded
xmodem:: I/O error
BAUD is set 115200, tired diffrent BAUD aswell, no luck.
Tried Reset cmd and erase flash, NO luck
Tried diffrent Terminals eg: ScureCRT and Zterm... Using MAC OS
Initial Boot loder line of switch
C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950G-24-EI starting...
Base ethernet MAC Address: 00:16:c7:a9:1d:80
Xmodem file system is available.
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 1536
flashfs[0]: Bytes available: 7739904
flashfs[0]: flashfs fsck took 4 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading ""...: permission denied
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
switch:
Please Help
0 Replies 0
