Possibility to use both Time Range ACL and PBR.
mhiyoshi
Level 3
Level 3
                   Hello
I would like to find out the attached requirement.
If there is any related information we greatly appreciate it.
Actually I have already configure on Cisco1812J by using the following command.
however the ACL status still shows "inactive" and the PBR does not function.
*Configuration on R1
time-range PBR-TIME
periodic weekdays 15:40 to 15:41
ip access-list extended PBR-TIME
permit ip host 10.0.30.11 host 1.1.1.1 time-range PBR-TIME
route-map PBR-TIME permit 10
match ip address PBR-TIME
set ip next-hop 10.0.20.3
interface Vlan1
ip address 10.0.30.1 255.255.255.0
ip policy route-map PBR-TIME
*Verification
R1#sh ip access-lists
Extended IP access list PBR-TIME
    10 permit ip host 10.0.30.11 host 1.1.1.1 time-range PBR-TIME (inactive)
R1#sh route-map
route-map PBR-TIME, permit, sequence 10
  Match clauses:
    ip address (access-lists): PBR-TIME
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
*Traceroute from SW1
SW1#traceroute 1.1.1.1
Tracing the route to 1.1.1.1
VRF info: (vrf in name/id, vrf out name/id)
  1 10.0.30.1 0 msec 0 msec 9 msec
  2 10.0.10.2 0 msec 0 msec 17 msec
  3 10.0.11.254 0 msec *  0 msec
in my opinion the config you posted is correct. Try to remove and re-apply on vlan1
ip policy route-map PBR-TIME, but if in this case will work is not correct, because the PBR doesn't need to remove and re-apply.
The second thing is to try to do a clear arp because the time-range is very short...
Third, check the time on switch with sh clock or sh ntp association to check if clock is synchronized or correct. But i think that you already checked.
Bye
cadet alain
Inactive means that you are not in the correct time-range so verify your clock and set it to correct time then it will go active and the PBR will be working.
Alain
Oh that is incredible!!
It has been functioning correctly like this.
Thank you for quick and precious advise.
Masanobu Hiyoshi
    10 permit ip host 10.0.30.11 host 1.1.1.1 time-range PBR-TIME (active) (45 matches)
(omit)
    10 permit ip host 10.0.30.11 host 1.1.1.1 time-range PBR-TIME (inactive) (45 matches)
R1#
  1 10.0.30.1 0 msec 0 msec 0 msec
  2 10.0.20.3 0 msec 0 msec 9 msec
  3 10.0.21.254 0 msec *  0 msec
  1 10.0.30.1 0 msec 9 msec 0 msec
  2 10.0.10.2 0 msec 0 msec 8 msec
