Errors on Cisco WS-C2950T-24 switch FastEthernet port
vladimir-simic
SW1#show interfaces fastEthernet 0/14 counters errors
Port        Align-Err    FCS-Err   Xmit-Err    Rcv-Err UnderSize
Fa0/14           6682     140364          0     306468         0
Port      Single-Col Multi-Col  Late-Col Excess-Col Carri-Sen     Runts    Giants
Fa0/14             0         0         0          0    180103         0      2798
SW1#show interfaces fastethernet 0/14
FastEthernet0/14 is down, line protocol is down (err-disabled)
  Hardware is Fast Ethernet, address is 0015.6204.1fce (bia 0015.6204.1fce)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 172/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 100BaseTX
  input flow-control is unsupported output flow-control is unsupported
  Last input never, output 3d00h, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     131027136 packets input, 2935317548 bytes, 0 no buffer
     Received 7643 broadcasts (0 multicast)
     0 runts, 2798 giants, 0 throttles
     149844 input errors, 140364 CRC, 6682 frame, 0 overrun, 0 ignored
     0 watchdog, 5267 multicast, 0 pause input
     75240868 packets output, 1154829616 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
What is problem with this port?
5 Replies 5
Jan Rolny
Level 3
Level 3
Hi Vladimir,
on first look your interface seems to be err-diabled (first line)
Please look to syslog for reason why interface is err-disabled. There can be number of reasons. Please post running config of interface. Do you have security applied to interface?
Jan
My configuration interface Fa0/14:
interface FastEthernet0/14
switchport access vlan 100
switchport mode access
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
Hi Vladimir,
are you able to check syslog messages? You should see reason in syslog. Please read this document to check all the resons mentioned:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml
Jan
barweiss45
With the information provided and the way you have the interfaced configured I'm assuming this is an access port with some host connected to it (phone, PC, both perhaps). Since portfast disables BPDU's on the the interface I don't think you have a spanning tree issue causing the interface to go err-disable, especially if it is truly an access port connected to a non-switch device. My guess is a possible duplex mis-match. If the other side is hard coded to full duplex then int fa0/14 will fall back to half duplex as duplex is not negotiated. If the duplex is auto then on the host, the its possible you have a physical layer issue. At that point you'll have to trouble each physical compent to determine the issue (the NIC on the host, the cable, the port on the switch, etc).
Leo Laohoo
Your line error is possibly caused by an execessive amount of "line flaps".  This is evident with the output.  Under "reliabiltiy" the values should be 255/255 and nothing LESS.
