errors
alsayed
Level 7
Level 7
Hello!
what this output does on my 6509 720:
1d01h: %PM-SP-4-LIMITS: The number of vlan-port instances on module 1 exceeded t
he recommended limit of 1800
this due to problems
10xs
Jon Marshall
Ali
See the recommended action at the bottom for a fix.
%PM-4-LIMITS: The number of vlan-port instances on [chars] exceeded the recommended limit of [dec].
This message means that the total number of individual VLAN ports, counted over the module or switch, has exceeded the recommended limit. VLANs can be counted more than once; if VLAN 1 is carried on ten interfaces, it will count as ten VLAN ports. On some platforms bundling is also ignored for purposes of this count; if eight interfaces on the same module are in one bundle, and the port channel is carrying VLAN 1, it will count as eight VLAN ports. [chars] is the module name (for example, switch or the module number), and [dec] is the recommended limit.
Recommended Action: Reduce the number of trunks and VLANs configured in the module or switch as recommended in [dec]. Enter the show interfaces trunk privileged EXEC command to see the total number of trunks and VLANs.
Jon
hello
10xs Jon..
In some cases like 6500 when all vlans is up and enabled and you configured even one trunk without allowed vlans the number of instances is exceeded
just limit the allowed vlans
