Establishing an IPSec VPN from Inside (ASA)
rdeangel
Community Member
Hi everybody,
Would anybody happen to know what needs to be done to allow a IPSec VPN session on the ASA to be established from an inside network.
I have it working on a Router but couldn't figure out just yet why it doesn't work on the ASA.
I apologize for posting this in the wrong forum.
andrew.prince
Level 11
Level 11
You configure a VPN as normal, but you just enable ISAKMP on the inside rather than the outside.
You also need to make sure your NAT is 100%.
I need it on both actually, inside and outside.
ktwaddell
Level 5
Level 5
We have an ASA with 2 VPN's on the outside and 2 on the inside, I don't remember treating it any different though I think NAT had been a b1tch.
what are you're logs saying?
