Ether channel configuration sync issue
HCL Support
Level 4
Level 4
We are facing the Ether Channel configuration sync issue as " Everytime when there is some issue with Etherchannel modules then we need to re-configure the Ether configuration again even if we either reset the problematic module or insert new module on same slot "
Common of all L3 switches is the module Part code: WS-X6748-GE-TX
Also attaching the show version, show module for these Switches. Suggest us if there is any bug impact with the current IOS running with these Switches or we have some Hardware issue with specific module part.
Ashutosh
Could you provide the configuration of the etherchannels in question?
