Removing self signed certificate
ALIAOF_
Level 6
Level 6
Is this a best pratice to leave these on the switch?  I do use ssh to manage the switch but I don't think these are needed for that purpose.  Any security concerns?
crypto pki trustpoint TP-self-signed-xxxxxxxxxxxx
crypto pki certificate chain TP-self-signed-xxxxxxxxxxx
From a security-standpoint, each function that you don't need should be disabled. As you don't need the certificates for SSH you can delete them. If you later decide to use HTTPS then you can add your own enterprise-generated certificate or generate new self-signed certificates.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
