Showing results forĀ
Search instead forĀ
Did you mean:Ā
Ether-Channel mode ON issue
anudeep_26
I have some issues running  ether-channel mode on. I have a 3120G Blade Switch (stacked). The blade  switch connects to the blade servers (internal).
Gi1/0/1 connects to eth0 and gi2/0/1 connects to eth1 on the blade server.
Here is my configuration:
interface Port-channel11
description Server1 | BOND 0 | HPBLADE BL460
switchport access vlan 11
switchport mode access
interface GigabitEthernet1/0/1
description Server1-eth0 | DOWNLINK
channel-group 11 mode on
interface GigabitEthernet2/0/1
description Server1-eth1| DOWNLINK
On the server eth0 and eth1 are bonded. Here is the config
cat ifcfg-bond0
DEVICE=bond0
BOOTPROTO=none
ONBOOT=yes
IPADDR=192.20.184.11
NETMASK=255.255.255.0
USERCTL=no
BONDING_OPTS="mode=2 miimon=100 xmit_hash_policy=2"
Everything works fine, the etherchannel is up and running.
The  issue is when is shutdown eth0 on the server, the corresponding  interface on the switch (gi1/0/1) does not go down, show up and running.  Can anyone help me on this?
Reza Sharifi
Can you change your config to run LACP and test again?  Make the switch side mode active.
Also, what happens if you shut the interface on the switch instead of the server when the mode in on?
Yes when i run my test with LACP everything works fine, but with mode on the switch does not recognize the server interface going down. With mode ON when i shudown the interface on switch, the server detects the link going down. Not sure if this is LINUX issue or CISCO..
Then just use LACP.  Unix and Linux products like standard protocols like LACP anyway.
