Ether Channel result.
cisco.net
Hii Guys,
I have to configure Ether-Channel between two links with different banwidth capacity i.e 10 Mb and 18 Mb.
Guess it should work,but have bit confusion that what would happen if low bandwidth link i.e 10 Mb will utilised peak. Is there may be errors or isolation.
Second, If i make etherchannel with three links with capacity 10 Mb , 10 Mb and 8 Mb then what would be the result.
PLease share if anyone have some good documents on the same.
hsw_networking
All elements of a port channel must be the same speed - I don't know how you would get an 18Meg ethernet connection anyway?
See document ref 12023
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
glen.grant
What you are saying cannot be done as previously posted all links must be equal , 100 meg , gig etc...
