Etherchannel - 3750 Stack
Thiago Cella
Level 4
Level 4
Hi friends,
I attached the topology to better understanding.
Follow the scenario:
- I have two 3750 in stack, and two 3560;
- I configured the etherchannel in all devices:
3750 stack:
3750(config)#interface portchannel 1
3750(config-if)#switchport trunk encapsulation dot1q
3750(config)#interface range gigabitethernet 1/0/0-1/0/1
3750(config-if)#channel-group 1 mode on
3750(config-if)#switchport mode trunk
3750(config)#interface range gigabitethernet 2/0/0-2/0/1
two 3560 :
3560(config)#interface portchannel 1
3560(config-if)#switchport trunk encapsulation dot1q
3560(config)#interface range gigabitethernet 0/0-/0/1
3560(config-if)#channel-group 1 mode on
3560(config-if)#switchport mode trunk
After configured, works about 3 minutes, and the ports on the 3750 stack are disabled . What could be, the IOS version?
glen.grant
  Why do you have 4 ports configured on the 3750 and only 2 on the 3560's.?  Check the logs it will tell you a lot of the time why the channel was taken down.
Leo Laohoo
Do a "sh log" and it will tell you WHY the channel went down.
Looking at your post above your etherchannel config is tupsy-turvey.  Put the physical interface into the channel-group FIRST.
