Etherchannel and cable category
o.mihailov
Will there be any problems if cables in etherchannel have different categories? In my case it's cat. 6 and cat. 5e.
Mark Malone
No should not be, you can mix with both cat 5/6 fully compatible I even think they made cat7 backward compatible as well just with better noise reduction and stronger frequency. Jst make sure your configs,speeds and duplex all match for etherchannels
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Unless you're exceeding the physical capabilities of a cable, there shouldn't be any problem.
Many thanks!
Mark Malone
