06-30-2017 01:41 AM - edited 03-08-2019 11:09 AM
Hello !
I'm trying to configure etherchannel between router 4431 and switch 3850, i need some advice how to configure etherchannel
06-30-2017 04:29 AM
Are you using any ether switch model on the 4431? are you going to use Layer 2 (VLAN or Trunks) or 3(IP addresses) etherchannel?
06-30-2017 05:58 AM
I'm don't know what the ISRs 4K support vis-a-vis Etherchannel, but on the older ISRs, you could often configure Etherchannel on their routed ports if you set it up as a manual Etherchannel (i.e. no LACP support).
