Need Help for Eigrp neighbor issue.
ht513067625
Hi guys.
I am currently having an EIGRP issue. I will make long story short.
Topology is simple, an ASA firewall connect to a Cisco switch, and running Eigrp. My question is from switch i show ip eigrp neighbor detail:
209-Remote#show ip eigrp neighbors detail
EIGRP-IPv4 Neighbors for AS(10)
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
0   10.209.130.1            Vl2130                   14 00:01:13    1  5000  1  0
   Version 9.8/3.0, Retrans: 15, Retries: 15, Waiting for Init, Waiting for Init Ack
   Topology-ids from peer - 0
    UPDATE seq 4289 ser 0-0 Sent 73630 Init Sequenced
Then i try do "debug eigrp packet" from firwall, I get following:
EIGRP: Sending HELLO on INSIDE
  AS 10, Flags 0x0:(NULL), Seq 0/0 interfaceQ 2046/2047 iidbQ un/rely 0/0
EIGRP: received packet with MD5 authentication, key id = 1
EIGRP: Received UPDATE on INSIDE nbr 10.209.130.254
  AS 10, Flags 0x1:(), Seq 4282/0 interfaceQ 2043/2047
EIGRP: Neighbor(10.209.130.254) not yet found
  AS 10, Flags 0x0:(NULL), Seq 0/0 interfaceQ 2041/2047 iidbQ un/rely 0/0
I find out ASA receive updates, but neighbor not yet found. Then I try ping 224.0.0.10,
Switch can get reply from the other 2 neighbors, but ASA get nothing.
I stuck at here and don't know what to do now.
This network worked well before. this morning I find out I cant ping ASA from my monitor system.
Any help will be appreciated.
Many thanks in advance!!
Tian
Francesco Molino
This issue means that asa doesn't receive any multicast traffic.
Stupid question but you can ping asa and switch from their connected subnet?
Can you check on asa if you get some multicast drop traffic?
Just to be sure that there isn't any other thing impacting the peering (acl or whatever), can you issue there command neighbor on both sides (asa and switch) to see if the peering is coming back UP.
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi Francesco,
thank you for your reply!
connected subnets are pingable, also there is no drop packets.
Nothing changed and no ACL.
Ok this is weird that you face the bug without doing anything while the everything was up and running before.
 can you setup the neighbor command in both side to check if owing is back up?
Can you share some outputs like:
Sh ip protocol, eigrp config, timeout of eigrp on both side?
Francesco
issue was resolved. But I am still confused.
so what I did is I remove the network statement under asa EIGRP  process, and put it back, then it works.
I tried the same way on the switch, but didnt work.
I really want to figure out the issue. One of our senior engineer told me he saw this happen before when there was asa failover, but I did the same thing to other clients network, there is no such issue.
anyway, thank you for your help!
Tian
