Etherchannel Catalyst 4006 and stacking 3750
peterblersch
i tryed to configure a etherchannel between a Catalyst 4006 CATOS 7.3 and a 2-stacked 3750 switch. I used 2 GB FX Ports.
I uses LACP with mode actice.
The ports did not build the channel.
Can there be a general problem with this hardware/software combination ?
Peter
glen.grant
I am not sure catos version 7.3 supported LACP I would verify that first. If not use use PAGP instead .
Amit Singh
CatOS 7.3 supports Lacp mode for ether-channels. Please see the config guide for the same.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/7.3/configuration/guide/channel.html#wp1032149
You have to make sure that your port configs on all the ports in an etherchannel has to be same. Configs regarding speed/duplex,STP,trunking feature all have to be exactly same on all the ports.
HTH,Please rate if it does.
-amit singh
i forgot to mention that i was using cross stack Etherchannel. I think the problem is that the C 4006 is using PSTP and the C3750 is configured with STP.
Can this be the issue ?
Peter
