Etherchannel config problem or HW problem?
Luis Ruiz Lopez
Hi all,
Hope you can help me out to figure out whether I have something wrong with the config of this etherchannel or if it's a hardware problem. Everything looks like a HW problem to me but maybe you can show me a different direction to handle this issue.
I have 2 Cisco Catalyst WS-C4006 running IOS version cat4000-i5s-mz.122-25.EWA14.bin with the following modules installed:
Mod Ports Card Type                              Model              Serial No.
1     2  Supervisor III 1000BaseX (GBIC)        WS-X4014
2     6  1000BaseX (GBIC)                       WS-X4306-GB
3     6  1000BaseX (GBIC)                       WS-X4306-GB
4    24  10/100BaseTX (FX-MT)                   WS-X4124-FX-MT
5    24  10/100/1000BaseT (RJ45)                WS-X4424-GB-RJ45
I have configured ectherchannel 6 as the trunk link between both switches (same config in both switches) with the following config:
interface Port-channel1
switchport
switchport mode trunk
storm-control broadcast level 5.00
storm-control action trap
spanning-tree guard root
and interfaces gig1/1 and gig1/2 with the following config (same config in both switches):
interface GigabitEthernet1/1
udld port
no snmp trap link-status
channel-group 6 mode on
interface GigabitEthernet1/2
udld port
I have changed the etherchannel mode to desirable and the same and I aslo tried with LACP instead of Pagp.
The story is that when I enable etherchannel 6, all vlans start flapping and I have to either shutdown inter gig1/2 to be able to leave the net stable or let UDLD do its job and remove the gig1/2 out of Po6 by placing the port in err-disable state mode when the loop is detected.
Here is the messages that I got:
Aug 31 03:34:03  %C4K_EBM-4-HOSTFLAPPING: Host 9C:AF:CA:94:17:90 in vlan 333 is flapping between port Po6 and port Gi2/5
Aug 31 03:34:06  %C4K_EBM-4-HOSTFLAPPING: Host 00:26:73:18:B4:7C in vlan 6 is flapping between port Po6 and port Gi2/4
Aug 31 03:34:06  %C4K_EBM-4-HOSTFLAPPING: Host BC:30:5B:B4:F5:09 in vlan 5 is flapping between port Po6 and port Gi2/6
Aug 31 03:34:11  %C4K_EBM-4-HOSTFLAPPING: Host 00:0A:B7:7D:49:FF in vlan 3 is flapping between port Po6 and port Gi2/5
Aug 31 03:34:12  %C4K_EBM-4-HOSTFLAPPING: Host 00:1E:4F:E3:14:C4 in vlan 6 is flapping between port Po6 and port Gi2/3
Aug 31 03:34:12  %C4K_EBM-4-HOSTFLAPPING: Host 00:0A:B7:7D:49:FF in vlan 6 is flapping between port Po6 and port Gi2/2
Aug 31 03:34:13  %C4K_EBM-4-HOSTFLAPPING: Host 00:1A:A0:55:60:1E in vlan 5 is flapping between port Po6 and port Gi2/6
Aug 31 03:34:18  %C4K_EBM-4-HOSTFLAPPING: Host 9C:AF:CA:94:17:90 in vlan 333 is flapping between port Gi2/5 and port Po6
Aug 31 03:34:23  %C4K_EBM-4-HOSTFLAPPING: Host 00:0A:B7:7D:49:FF in vlan 3 is flapping between port Po6 and port Gi2/5
Aug 31 03:34:25  %C4K_EBM-4-HOSTFLAPPING: Host 00:0A:B7:7D:49:FF in vlan 5 is flapping between port Po6 and port Gi2/2
Aug 31 03:34:25  %C4K_EBM-4-HOSTFLAPPING: Host 00:0A:B7:7D:49:FF in vlan 6 is flapping between port Po6 and port Gi2/2
Aug 31 03:34:32  %C4K_EBM-4-HOSTFLAPPING: Host 00:0A:B7:7D:49:FF in vlan 333 is flapping between port Po6 and port Gi2/5
Aug 31 03:34:33  %C4K_EBM-4-HOSTFLAPPING: Host 9C:AF:CA:94:17:90 in vlan 333 is flapping between port Po6 and port Gi2/5
Aug 31 03:34:37  %C4K_EBM-4-HOSTFLAPPING: Host 00:1E:4F:E3:17:12 in vlan 6 is flapping between port Po6 and port Gi2/3
I tried configuring interfaces gig 5/20 and 5/21 into Po6 and the problem doesnt occur. It is only happening with inter gig 1/2.
If I put gig1/1 and gig1/2 to work together then the flapping starts.
If I put gig1/1 to work alone the flapping stops
If I put gig1/2 to work alone the flapping starts.
And finally two different gig interfaces working together work fine.
So the problem seems to me like a HW problem. Any suggestions?
P.S. I'm using fiber links and one of the supervisor cards has already been changed and also different fibers have been used to discard problem with the fiber.
Thanks a lot for your support and ideas and sorry for this long message!!!
Well yes and no. I just realised. You specify channel-group 6 mode on, but your configuration is for port-channel 1.
You should have a port-channel 6.
If that doesn't fix it, it will be a dodgy SFP (mini-gbic) by the sounds of it.
HTH,
Ian
11 Replies 11
IAN WHITMORE
Level 9
Level 9
If you're saying thay UDLD kicks in then you have a unidirectional link on a fibre...which means either one of the pairs of one fibre isn't working, or the fibre SFP is not working right.
So your best bet is to switch the SFP's and see if that works (as you said you already checked and switches the fibre itself).
HTH,
Ian
I actually changed the fibers 2 times so I guess this means the problem should not be on the fibers. Apparently the supervisor card has been changed in both switches but that is something that I need to make sure of.
The fiber that was used to connect gig5/20 and 5/21 and that worked well is the one in use now for gig1/1 and 1/2.
Do you think thats the only thing that could be affecting the well functioning of the etherchannel?
Thanks a lot for your very quick reply!!
Luis
HTH,
Ian
oh well, sorry about that, it was a mistake.. Thats is because at first I was using Portchannel1 and of the things I did was to create portchannel 6 with the same configuration as Portchannel1 and tried but I'm using port channel 6.
I'll try few things with the SFPs to see if I can fix it and get back to you.
Thx
OK matey. Hope it works out for you.
Ian
Hi Ian,
Unfortunately the problem persist.I have changed the GBICs, fibers and still the same.
When I check UDLD status on both switches, the problem is always in ST02 interface gig1/2 even when I swap the GBICs from ST02 to SR03.
If its not the GBIC, what else could be?
Any other idea or sugestion?
Thanks a lot
Luis
Move the interface to a different port.  If the issue goes away then you've got a BIGGER issue.
I've tried configuring the etherchannel using interfaces gig 5/20 and 5/21 (SFPs) and the etherchannel works ok. It only happens with int gig1/2 (GBIC).
So you also think it is more a HW problem? Apparently the supervisor card III was also replaced on that switch some time ago.
What is your idea?
Indeed.  HW issue.
Can you reboot the chassis?  Sometimes if there's an issue with the port it will show up during the POST.
Julio Garcia
Level 6
Level 6
can you do #sh interface gi  x/x  capabilities
and compare the two outputs  , check if 'channel' section has 'yes'
I' ve issued the command on both interfaces and the same ouput is given:
GigabitEthernet1/2
  Model:                 WS-X4014-Gbic
  Type:                  1000BaseSX
  Speed:                 1000
  Duplex:                full
  Trunk encap. type:     802.1Q,ISL
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100), hw
  Flowcontrol:           rx-(off,on,desired),tx-(off,on,desired)
  VLAN Membership:       static, dynamic
  Fast Start:            yes
  Queuing:               rx-(N/A), tx-(1p3q1t, Sharing/Shaping)
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  SPAN:                  source/destination
  UDLD:                  yes
  Link Debounce:         no
  Link Debounce Time:    no
  Port Security:         yes
  Dot1x:                 yes
  Maximum MTU:           9198 bytes (Jumbo Frames)
  Multiple Media Types:  no
  Diagnostic Monitoring: no
When I reloaded the routers one of the times and I think one of the interfaces was blinking with an orange light.
